Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link |
Shockworks is proud to announce testing for our brake kits is complete and production has commenced with stocks available in April.
Pricing starts at $1800 for the front upgrade with fixed disc, then $2000 for the floating disc assembly. Rears are still under final stages of development and will be available soon. Colours as seen in picture were only for development purposes with a final colour yet to be decided. ![]() |
Im very interested in upgrading the brakes on my bf turbo ute. For the $1800 what do we get? Calipers, rotors, pads, caliper brackets and lines?
Also what are your rears going to be?
Seduce BFII XR6T Ute ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw |
Am interested, but would need to know whether they would fit under the factory 19 inch 10spoke fg g6et wheels (I've heard brembos don't fit under these wheels so curious to know if these monoblocks would fit)
Cheers |
Have you got a picture with the wheel on??
FG XR6 Turbo - 345rwkws @ 16psi
GTX3582r - plazmaman piping/turbo side intake - injectors high flow cat - ZF tune - build thread Tuned by Bluepower |
#5 | |||
The kit comes with the discs, calipers and caliper brackets. We are working on a braided brake line option for the kit. We used the standard brake line from the standard calipers but feel would get the best out of the new system with a better quality line. We will be offering a replacement disc for the rear and looking at options for a suitable caliper but feel most of the work done is at the front. It seems that at Winton and other tracks when the front brakes are strong the rears cope well. We have two options for the pad that come with the kit. One is a street pad with very low brake dust and our S1 pad for street and the track. Cheers |
#6 | |||
Cheers |
What are the dimension specs for the rotors with this kit, and if you could, estimated replacement costs for the rotors?
#9 | |||
Cheers |
#10 | |||
The current disc that has been developed is a 355 x 32.5 radial vane design which we use on the Korean race cars for a while now with no issues. I estimate the cost for replacement discs at around $600 for the pair. This is just the rotor without the alloy hat as a replacement. We may also release a 380mm rotor for the Ford but need to do some more clearance tests first. Our discs are used in the Korean V8 Supercar series where we supply the whole field with brakes and dampers. Cheers Brett ![]() ![]() Last edited by Shockworks; 20-02-2014 at 09:56 AM. |
AWD Assassin
Hi Brett
What is the complete cost of the rotor and alloy hat and what colour hats will you release for sale. Keep up the great work and great products. Still luvin those coil overs mate , GT is so much fun to drive with em. |
#12 | ||
Please keep us posted about your endeavors with the 380mm rotors and the rear caliper setup. Put me down for a set with braided lines as soon as they are released!
2010 FPV GS 5.0 manual Shockworks adjustable coilovers, 19 x 9.5 volk racing te37 superlaps, Stainless headers, cats & Twin 3" exhaust. KPM 1500hp fuel system. Chromoly axles, Truetrac, Carbon Fibre tailshaft, ID1000s, Big Herrod cooler, Yella Terra snout, GT-P seats. 458 rwkw/1020Nm e85, 430/950 98ron 10psi Audio: 8 Channel active setup Clarion HX-D2 Special Edition Crescendo Opus 9.9 A pillars + doors Audison LRX 3.1k & LRX 4.5 Boston acoustics SPG 555 |
#13 | |||
The cost of the disc replacement for the Brembo bakes we estimate to be around $800. This is with the alloy hat and we have chosen a dark grey colour as the gold was a bit bright haha. The fully floating option will be about $100 extra. We have been bashing the brakes for the last month with outstanding results!! Cheers Brett |
#14 | |||
AWD Assassin
That's price competitice with the DBA 2 piece units ( 5000 series T3 2 piece rotors ) - actually yours are cheaper by a fair margin. How do they compare to the DBA units ? I'll need a set soon - so I have plenty of questions. LOL |
#15 | ||
Um.....goes fast.....gets round corners fast....pulls up freakin fast!!
I am very impressed with the gear that Shockworks produce! I have had Brett and Chris's 355mm 4 piston monobloc front brake kit put in this morning and with a couple hours driving round I can say that the progressive and predictable pedal feel coupled with the stopping power have again transformed the car. I will be giving them a good workout over the next few days :-) Apparently the full production kits will have a grey alloy hat rather than the orange, which will look the goods I reckon. Awesome gear for a reasonable price too!
2010 mk1 GS sedan with 412rwkw thanks to Pitlane Performance! KPM Street fighter stage 2 intercooler with 70mm pulley 1000cc injectors Herrod Fuel pump BMC air filter Built tailshaft Shockworks Coilovers Shockworks 4 piston monobloc front brake kit Herrod oil breather and "special" diff breather kit 19x9.5 rears 19x8.5 fronts with sticky Michelin rubber ![]() |
#16 | |||
I did slip up a little with the price, as I had quoted for the smaller 320mm units we use on the GT86 so sorry about that mate. The 355mm rotors with the alloy hats for the Ford Falcon will be $900 a pair. The fully floating is to be around $1050 as it is more expensive to produce and assemble. I can not say for sure how they compare with the DBA rotors which are recognised as quite good. All I can say is that the same rotor design we use are used on many races cars with very good results and are durable. All the testing we have performed so far has been outstanding. I have been involved in damper and brake testing for many years and feel our package is very predictable on the limit and with very good feedback. Less effort than some other monobloc callipers we have tested. We are still trying to source a high quality braided line for the kit but all testing so far has been with the factory brake line, so expect even better results with an improved brake line. Cheers Brett Last edited by Shockworks; 05-03-2014 at 12:10 PM. Reason: clean up |
#17 | ||
Hey Brett,
forgot to ask yesterday, what sort of replacement cost are we looking at for the pads, the track/street ones which are in the car now? Cheers, Nathan
#18 | ||
#19 | ||
Awesome,
Thanks Brett, have you decided on final colour of alloy hat and calliper yet? another thing i forgot to ask yesterday...figured id ask on the forum so that others can get the info also.... :-)
#20 | ||
Hey Natedog,
They will be anodized a dark grey so they look a bit more subtle and don't clash color wise with the caliper. I will be in Korea in the next month so will get some photos of the brakes being manufactured at the plant. Amazing production line and facilities. Cheers Brett |
#21 | ||
Thanks Brett,
When will the first sets hit Oz? I NEED them :-)
#22 | ||
#23 | ||
With a definate price i may be interested in the pre-sale kits.
#24 | |||
The front kit using the 355mm fixed rotors with alloy hat and our Shockworks Mando calliper will be $1800. The floating option with the 355mm disc and callipers is $2000. The callipers come with the low dust street pads. The S1 track pad is an $80 option for the kit. So far we have tested with the standard Ford brake line and will have a braided line available with the kit as an option soon. Prices for the lines are still to be confirmed. I hope this helps!! Cheers Brett |
#25 | |||
So when I've worn out the first set of S1 pads how much to replace them?
#26 | ||
Hi Brett,
I know you are getting bombarded with questions atm haha but here is another one How is wheel clearance diameter wise with the new caliper over the Brembo 4 pot? I have Enkei RPF1 18" rims and I am worried about wheel clearance, there is prob 4mm clearance right now with the Brembo 4 pot. Cheers Dave
FG MKII GT ZF, 444.8rwkw, 61mm YT snout, 1000cc injectors, 460lph fuel pump, big kpm intercooler, shockworks w/12kg front springs, SSR GTX01 18X9.5" +22 F/R, nizpro input shaft, 1pce 4" AL tailshaft, poly bushings all round, trutrac, headerback exhaust 3", whiteline sway bars, IMS diff hat, herrod spark booster, Alpine R type speakers/Alpine R type 2x12" ported subs/Pioneer GM-D9601/8604 amps and other bits |
#27 | |||
2010 mk1 GS sedan with 412rwkw thanks to Pitlane Performance! KPM Street fighter stage 2 intercooler with 70mm pulley 1000cc injectors Herrod Fuel pump BMC air filter Built tailshaft Shockworks Coilovers Shockworks 4 piston monobloc front brake kit Herrod oil breather and "special" diff breather kit 19x9.5 rears 19x8.5 fronts with sticky Michelin rubber ![]() Last edited by natedog; 06-03-2014 at 03:30 PM. |
#28 | |||
Natedog may be some help with the info he has just supplied, and we will have to wait until we get the brakes back to confirm for you. Can you give us the ID of the rim so we can do a clearance check? We will try and get them back soon but may be a little bit of a challenge as the test driver (natedog) seems to be having too much fun!! Cheers |
#29 | |||
If you can measure the distance from the centre of your wheel to the inner circumference of the wheel as accurately as possible I can do the same and it might help? Or I can drive up to Sydney to show them to you....is that cool Brett?? ![]()
2010 mk1 GS sedan with 412rwkw thanks to Pitlane Performance! KPM Street fighter stage 2 intercooler with 70mm pulley 1000cc injectors Herrod Fuel pump BMC air filter Built tailshaft Shockworks Coilovers Shockworks 4 piston monobloc front brake kit Herrod oil breather and "special" diff breather kit 19x9.5 rears 19x8.5 fronts with sticky Michelin rubber ![]() Last edited by natedog; 06-03-2014 at 03:51 PM. |
#30 | ||
We will now be getting a supply of Goodridge braided brake lines from Howard Reynold's Race Brakes which are ADR approved for our Ford brake upgrades. Howard has so many years of experience. He even supported me in the early 90's when I was tearing up the tracks around Victoria!!
