Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link |
#31 | ||
On the front.
http://www.enkei.com/rpf1.shtml# http://www.enkei.com/size_chart/RPF1.pdf 3798856530SP 18 X 8.5 +30 Thanks Natedog. This will help if the inner diameter of the wheel is the same as my stock GT 19" rim. Should give me a starting point.
FG MKII GT ZF, 444.8rwkw, 61mm YT snout, 1000cc injectors, 460lph fuel pump, big kpm intercooler, shockworks w/12kg front springs, SSR GTX01 18X9.5" +22 F/R, nizpro input shaft, 1pce 4" AL tailshaft, poly bushings all round, trutrac, headerback exhaust 3", whiteline sway bars, IMS diff hat, herrod spark booster, Alpine R type speakers/Alpine R type 2x12" ported subs/Pioneer GM-D9601/8604 amps and other bits |
#32 | ||
Hey Brett,
If they fit 18s im really keen. If need be i can drive up and test fit and bring one of my old factory 19s to see if they fit as well. Cheers, Luke |
#33 | |||
2010 mk1 GS sedan with 412rwkw thanks to Pitlane Performance! KPM Street fighter stage 2 intercooler with 70mm pulley 1000cc injectors Herrod Fuel pump BMC air filter Built tailshaft Shockworks Coilovers Shockworks 4 piston monobloc front brake kit Herrod oil breather and "special" diff breather kit 19x9.5 rears 19x8.5 fronts with sticky Michelin rubber ![]() Last edited by natedog; 05-06-2014 at 05:47 PM. |
#34 | ||
I just did a measurement as accurate as I could and I have 21mm clearance with the Brembo 4 pot and stock GT rim, putting the 18" on that is reduced to about 7mm. It will be really cutting it fine lol
I would need to do a test fit before buying to be comfortable with fitment some how. ![]()
#35 | ||
I had to give Brett his test brake kit yesterday and in went my old worn out little rotors.
After driving them around through every day stop start, freeway and a few hard braking tests, all I can do is highly recommend these kits once they are released next month! The street/track pads that I tested were not dusty. They were not squealy hot or cold. The pads did not need heat up to work from cold starts like some street/track pads require. They did not fade....even with me trying to get them to.....all I did was destroy my rear pads!!!! Poor little rotors, they were coming to the end of their lives anyway :-) My order is in, I am definitely getting the Shockworks brake kit. When the Shockworks kit was taken off there was no hint of any higher than normal wear from me "trying" to get them to fade on a couple "test" sessions. Pedal feel is progressive and predictable, there is no hint of them being unpredictably "grabby" at any speed hot or cold. Awesome front brake upgrade for the $$$ I must thank Brett for letting me test the kit out.....the fact he was willing to lend them to me to try and beat them up a bit after only having met him a month earlier?? Shows the faith he has in the product to lend them to a stranger basically... and he's a good bloke! Nathan
2010 mk1 GS sedan with 412rwkw thanks to Pitlane Performance! KPM Street fighter stage 2 intercooler with 70mm pulley 1000cc injectors Herrod Fuel pump BMC air filter Built tailshaft Shockworks Coilovers Shockworks 4 piston monobloc front brake kit Herrod oil breather and "special" diff breather kit 19x9.5 rears 19x8.5 fronts with sticky Michelin rubber ![]() |
#36 | ||
Hi Guy's,
We did some measurements on the brake calliper and rotor and from the centre of the hub to the outside of the calliper is 207.5mm. This should help to understand what rims will fit with our brake upgrade. Cheers Brett |
#37 | ||
Hi guys, looking good, very impressive how quick you've got this kit to market!!
Say, do you know how much this kit weighs, compared to the factory 355mm/4pot Brembos? Also, is it lighter or heavier than the 355mm dba 5000 series 2 piece rotor? Cheers |
#38 | |||
We don't have a DBA rotor to compare the weights so a bit hard to say. I know we are around 2 Kg lighter than the factory disc. I will get my hands on a Brembo caliper and compare the difference. We were able to get to market quickly as we already supply brakes through our Korean partner who support many race teams and also supply brake upgrade for many models in their market. Cheers Brett |
#39 | ||
Nice one, thanks.
Totally understandable that you don't have a dba rotor, but do you know the exact weight of your rotor? |
#40 | ||
Is there an estimated time for these to be on sale?
Seduce BFII XR6T Ute ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw |
#42 | ||
Hi Brendan,
We are expecting the brakes by the end of the month as they are being prepared for shipping now via sea. We will be airfreighting in a couple of sets but will split the difference in the cost of this if the demand requires this. We now have the Goodridge/braided line upgrade as an option for the caliper for $180 Cheers |
#43 | ||
Just wondering in terms of replacements pads for these, whether they use a generic pad design and are able use replacement pads from other brands (e.g ferodo, bendix, ebc)
cheers |
#44 | ||
If a 19" G6ET rim will clear these, I'm keen.
10 FG G6ET - Rocket-powered lounge suite. 430rwkW/950Nm. |
#45 | |||
I am not sure about the Ferodo or Bendix and looking into this now. If we find something, I will post some part numbers. It is a caliper supplied by Hyundai so will be able to get a part number for there replacement. We are importing many sets of pads for the street and track. We are also working with Howard Reynolds at Race Brakes to make a replacement pad that will be available for both street and track. Will update what we find soon. Cheers Brett |
#46 | |||
Build Thread: BA XR8 with all the goodies. fordforums.com.au/showthread.php?t=11247663 |
#47 | ||
I believe kits may be available as early as next week!
I can't wait!
#48 | ||
Bit disappointed about lack of information over the last 4 weeks. Nothing about the early sets that were going to be sent. Or the delay. Weren't these suppose to be available last month.
#49 | |||
Sorry for the info slowing down mate. I have been in Korea for the past three weeks testing and catching up while back for the last couple of days. The ship has arrived and we will have full stocks of the brake kits next week. There will be a slight delay on the floating rotor assembly as I was not happy with the pin design and are being air freighted on the 22nd. The fixed rotor and calliper will be ready for sale next week though. Cheers Brett |
#50 | |||
Cheers |
#51 | ||
Hi all,
I am getting the Shockworks brake kit put in next Wednesday, looking forward to some real stopping power compared to the stock calipers I've been thrashing round the track. Poor little discs...... :-) Will load up some pics once done
#52 | ||
They went on today....they look gooooood :-)
#53 | ||
AWD Assassin
Do you have the rubber or braided lines.
#54 | ||
#55 | ||
AWD Assassin
#56 | ||
Call me dirt... Joe Dirt
Sorry if this was already asked, but these new rotors will fit with the factory Brembo 4/6 pot callipers?
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
#57 | |||
We have a different design that suits the Brembo calliper. The Brembo has a smaller disc contact area than our calliper so made a new design for the Brembo's. The Brembo has 57mm of disc contact and our new calliper has 61mm so we have both types. Cheers |
#58 | ||
Do you have more in black? Just got some rear calipers in black and would like to continue the theme.
#59 | |||
We have plenty in the black and think it looks very cool for the first time on Natdog's car. We will also offer a couple of options for the colour of the alloy hat like a gun blue and the gold. That will be later in the year once we finish the other Ford range we are working on. Cheers |
#60 | ||
Not answering PM's?
