Go Back   Australian Ford Forums > General Topics > Non Ford Related Community Forums > Project Builds (non Car)
Project Builds (non Car) Here is an area where you can show / discuss other non car builds be they bikes, caravans, boats, BBQ's or whatever.
Old 01-06-2020, 02:34 PM   #1
roKWiz
Cabover nut
roKWiz's Avatar
Default Old motorhome to a cabin conversion
This one is from a few years back now. (so please excuse the picture quality)
This is the story of the 2nd motorhome I had built from a truck, (that's another story) used for 10 years while working up and down the Eastcoast and deciding to retire it from the road in a dignified way.
Part 1
Living aboard a boat in NSW and previously finding ourselves a big annual site in a little caravan park for the now well used truck MH, out of necessity I needed a base in NE Victoria due to the amount of contract stonework.
The nice then owner of the park gave us a huge corner plot with an ensuite then told us we were free to do whatever we liked.
The so called simply plan was to take the already converted body off the chassis and use as is but ideas sorta got in the way. In the meantime I could build the 3rd motorhome (current one) here at the same time.
The rusty poor old Daihatsu cab chassis was worn out after years of pulling this heavy pantec body up and down mountains. So I proceeded to pull the lower side skirts off of it and prepare it to be set up on piers.
I set the block piers so it would take advantage of the lovely shade trees and look out over the surrounding foothills towards Mt Buffalo.
Everything under the floor had to be disconnected and moved to allow a crane to come in a lift the body off the chassis, swing it 90deg and land it on the piers in a tight area.
He did managed to position it exactly where I wanted it so I could hook up power and water lines as before.
The trucks rusty cab was bogged up and a local transport company bought it off me and serves as their yard water truck still.
Some decorative gravel and pavers prettied the walkway up from the gate.
Give it a little garden granite wall and job done.....but.....
I got to thinking ????
Why not make it bigger.
Stay tuned for part 2.
Old 01-06-2020, 02:35 PM   #2
blueoval
Critical Thinker
blueoval's Avatar
Default Re: Old motorhome to a cabin conversion
Subscribed
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 02-06-2020, 01:35 PM   #3
roKWiz
Cabover nut
roKWiz's Avatar
Part 2
Now having the basic idea in my head sorted, work started........
We wanted to be able to have a fixed normal floor level bed, which wasn't possible with it's current layout of overcab bed.
Another aim was to use as much recycled materials I could reuse or source locally.
Seemed logical to extend the floor space, move the front mounted bed. The old conversion was set up with a workshop and storage area behind the rear barn doors with the bathroom forward of that. Kitchen midships and lounge forward under hinged down bed.
The new bedroom would be located at the rear where the workshop area was. I could build a timber frame floor level out from the back barn doors and keep them fitted during the construction to keep it watertight. The freestanding granite wall would act as a boundary wall for us, as well as the internal feature wall for the little bedroom. Another plus was it acted as a thermal wall during summer as it was directly in line with the setting summer sun.
Leaving little openings in the wall (putlocks) received the beams ends to tie the floor in.
As I casually built the wall between other jobs. We wanted to have a rounded roof and little observation (tea) room which as previously stated, looked towards Mt Buffalo. The top platform and shape was basically 18mm formply as it was strong and didn't need extra finishing, a couple of local demolition windows used. Next I ordered the curved Zincalume roof sheets at (12ft) 3.6mt span to allowing for an overhang. it was handy still having the old cab chassis to pick it up.
Long demo Oregon 4" X 2" timber lengths were screwed to the outside top edge of the sides so the curved roofing cound be then screwed down to it. At 900m intervals a formply bulkhead was installed crossways to add strength to the curve.
A new cladding was decided upon using thin marine ply simply sanded and coated in Deks Olje (a traditional marine tung oil coating) which acts like spar varnish and can handle dry summers here. Best of all it doesn't need stripping down every time a re coat is applied.
I had plenty from the boat.
The cladding needed an air gap so it was best affixed with more CD ply battens stood off the original cargosheet cladding I used 10 years previous.
Work progressed nicely on the top section ply coatings as they were big (8 X 4) 2440 x 1220mm pieces. Timber boxing around the caravan type windows was necessary to allow for a recessed look and I couldn't be bothered pulling windows out and reinstalling them.
The bottom cladding would be mini orb sheeting from the same local steel suppliers and just a matter of tek screwing them on.
It was back down to the demo yard to find a steel ?? belt line joiner between top and bottom cladding. Aluminium U in long lengths was the decider (due to price mainly.)
The freestanding bedroom wall grew as this was taking shape.
With most of the cladding done in the middle now it was time to work out the ends. The front needed a porch and doorway, while the back needed a roof spanning back to the stonework.
see you for part 3. for the ramshackle cheap ar*e cabin.
Old 14-06-2020, 01:06 PM   #4
roKWiz
Cabover nut
roKWiz's Avatar
PART 3
I'll continue this thread in between building the next cabin project currently underway.
Progress on the freestanding wall continued with squaring up Harcourt blocks needed for the corners and ends.
As the wall grew, I could then span the gap with roof beams to tie into the granite. Allowing the original pantec MH body to be connected as one unit.
My mason's mark I like to add to every stone job I build.
With the curved roofing secure, it was time to fill in the gap. Simple CD ply and timber framing was built as the side walling for the small bedroom running 12v wiring through these panels with wool insulation followed by the continuation of the side cladding to finish.
The front sheet metal of the luton peak was cut for the flooring and sides to extent and allow a front glass side panel door I had been storing. The door was a nice old one I picked up years ago when the house I rented was demolished and kept it stored or years. (now on the new cabin too)
A small front porch was built to view the paddocks next door.
As with most of the panels above I used formply for the door side filler panels, bulkhead above with timber frame and roofing offcuts to form the front awning.
Back wall completed and side wall panels done, sans trim. I source a used matching caravan window for the little bedroom.
Inside a mantel shelf was placed just to break up the stonework.
Overall this little place was a great base we initially set up until I later bought land down the road.
Old 14-06-2020, 06:30 PM   #5
Great work.
Do you have an apprentice? Would be a shame to not pass on your skills to another generation.
Old 16-06-2020, 08:20 AM   #6
roKWiz
Cabover nut
roKWiz's Avatar
Originally Posted by DFB FGXR6 View Post
Great work.
Thanks DFB,
Yep sound easy but convincing an offsider to live on the road with their own accommodation, not so.
Old 19-06-2020, 12:04 PM   #7
roKWiz
Cabover nut
roKWiz's Avatar
As a side note to this build.....
After we had lived in it for a few years the nice owner had to sell the little caravan park.
The new owner that came in (with all the big plans) decided that he wanted all the annual sites cleared but wanted my stonewall left.
I would have just given it to him but he turned out to be such a huge a***hole most annual tourist left anyway.
It was time to recycle everything yet again.
These pictures are of the IPEC delivery body I converted into the motorhome from a flatbed Daihatsu Delta.
Body cut and fitted to cab chassis.
Cladding mid fitout.
In use at the start.
Timing was perfect, as I was pulling the stone wall apart I needed several loads of the granite up at a local job at Silver Creek. The current boundary walling on this property (below) was my original feature wall of the little cabin.
Quite a few bits and pieces have found their way into the build of my new cabin still under construction including the nice flute glass doorway from years ago.
As for the pantec body, across the road from the caravan park was a rural supply where a young guy who raced motorcross worked, he was looking at converting a truck body into his accommodation and transport of his bikes to race meeting.
A deal was struck where I didn't even have to remove it, the last I heard he had it on another cab chassis and was refitting it out again.
Old 19-06-2020, 01:01 PM   #8
Great to hear the incoming prat received his dues. Win.
Old 19-06-2020, 01:24 PM   #9
roKWiz
Cabover nut
roKWiz's Avatar
Yes, everyone took their bat and ball.
No one stays there much now, he ruined it.
Old 05-09-2020, 06:10 PM   #10
HIPO
Al
HIPO's Avatar
Good story & great work!
HIPO is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2020, 04:48 PM   #11
stock1991
Limited supply
stock1991's Avatar
"As I casually built the wall" amazing work. I want to be around you if there is ever a zombie apocalypse.......... wait
stock1991 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2020, 06:57 PM   #12
Cashie
Cashie's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Multiple helpful contributions throughout the tech area.
Wow, that was a great home build.
Current Rides:
2017 Ford Mustang
2020 Ford Everest Sport
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2008 BF XR6 Turbo Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Cashie is offline   Reply With Quote Multi-Quote with this Post
