26-10-2007, 08:34 PM | #1 | ||
Formerly MR BAXR6t
Hey all,
I just thought id share my lonnnggg list of problems with u all! Its booked into the mechanic on monday but ive only had the car for 3 months and i got a decent list of probs that dont look like there gunna be cheap to fix. 1. Grind noise when taking off at low revs around 700-1000 rpm 2. Alot of "play" in steering 3. No handbrake!! 4. Very rough idle 5 Wobble sort of noise when driving, which becomes worse when turning right 6. Clunk sorta noise when hittin the accelerator, sounds like coming form diff? 7. Crazy shakes when hittin 120kmph 8. Hard to put in 1st and reverse 9. Also leaking near steering column on my leg!!! As u can see its a decent list and dont seem like cheap fixes. U probably all notice im always on the forum with my never ending problems. Cant wait for the bill on monday!! :togo:
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
26-10-2007, 08:47 PM | #2 | ||
3. No handbrake!!
you can just adjust the handbrake shoes on the rear rotors 4. Very rough idle check airbox, ISC valve, clean throttle body, spark plugs, O2 sensor 5 Wobble sort of noise when driving, which becomes worse when turning right check tyres, get alignment or rotate the tyres 7. Crazy shakes when hittin 120kmph rotors are warped...get new ones....or DONT SPEED!! :P 8. Hard to put in 1st and reverse check gearbox fluid, clutch and clutch cable,etc or if auto i got no idea 9. Also leaking near steering column on my leg!!! mines is doing this too but its insurances problem ill let you know how they fix this id say just bring it to a mechanic and get it sorted one time, or hit a tree and claim insurance
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
26-10-2007, 09:45 PM | #3 | ||
Formally Kia Chaser
sounds to me like a broken Watts linkage.... lol
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
26-10-2007, 10:02 PM | #4 | |||
26-10-2007, 10:13 PM | #5 | |||
Fiat POWAAH!
Correct! as shown here: A simple shunt could shear this bolt right off. God bless Crompo! |
26-10-2007, 10:36 PM | #6 | ||
WHAP!!! POW!!! ZORK!!!
Probs 8 and 9 are related.
You probably have a cracked firewall, hence the water leaking in by the steering column, This in turn leads to clutch problems and gearshift probs. I just had mine welded up, with reinforced plates to stop it from happening again. Careful may lead to other more serious problems soon. Quotes to weld up range from $300 to $900 depending on the severity of the crack.
CAR: 99 Fairmont,Silver Engine: 5.0L,Tickford intake,extractors,exhaust. Suspension: Koni adjustables lowered. Bodykit: Havoc Wheels:XR8 AUII 17's Interior: upgraded to Ghia,rebolstered seats. Have parts just need fitting: Territory front brakes, Police issue rear brakes,Full sound system,Alpine HU/Processors,Focal speakers,Xtant amps. |
26-10-2007, 11:31 PM | #7 | ||
Formerly MR BAXR6t
awsum! So looks like i could be up for a couple of grand! :togo:
26-10-2007, 11:42 PM | #8 | |||
Fiat POWAAH!
26-10-2007, 11:44 PM | #9 | |||
Formerly MR BAXR6t
27-10-2007, 11:26 AM | #10 | ||
Sales Representative
You call that a list?... I'll take a leaf out of your book and list up my problems... i put them on a piece of A4 paper in 2 columns. :P
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
27-10-2007, 11:58 AM | #11 | |||
Formerly MR BAXR6t
27-10-2007, 01:29 PM | #12 | |||
27-10-2007, 02:05 PM | #13 | |||
Formerly MR BAXR6t
28-10-2007, 06:01 PM | #14 | ||
T3 TE50 Blueprint
Keep ya chin up mate, just go down your list and tick em off as you go. Can be frustrating I know, but once they are fixed they should be right for a long time. Just like the rest of us, you learn as you go. Just by staying on the forums you will be surprised at how much your knowlege will improve just by asking questions and reading heaps of threads. -craig
28-10-2007, 10:52 PM | #15 | |||
Walking with God
GK
29-10-2007, 12:28 AM | #16 | |||
Formerly MR BAXR6t
29-10-2007, 07:00 PM | #17 | ||
Formerly MR BAXR6t
Got the car back from the mechancis this was the problems
1. Grind noise when taking off at low revs around 700-1000 rpm- Some bearing needs replacing. Was told not to worry bout it, if you take the box out might as well give it a rebuid while its out! 2. Alot of "play" in steering- Steering rack problem 3. No handbrake!! - Tightened 4. Very rough idle - Fuel filter change, could do with injector service 5 Wobble sort of noise when driving, which becomes worse when turning right- Left rear wheel bearing 7. Crazy shakes when hittin 120kmph- Needed wheel balance BADLY 8. Hard to put in 1st and reverse- Changed oil, also to do with no.1 9. Also leaking near steering column on my leg!!! - Still unsure
30-10-2007, 12:11 PM | #18 | ||
How rough is the idle? AU V8's have a rough idle when they get some k's up as the valve guides wear, my T2 idles like it has a lumpy cam but it just worn guides.
30-10-2007, 01:51 PM | #19 | ||
_Oo===oO_
How many kms has your XR8 done mrauxr8?
I find it hard to select reverse sometimes, (dont know if its just 'me') but no dramas with 1st. |
30-10-2007, 07:57 PM | #20 | ||
Formerly MR BAXR6t
its done bout 130000k's
Its not a REAL rough idle, just enough to annoy you when sitting at a set of lights etc. ive changed fuel filter spark plugs etc. But still the same, so might be valves as u suggested. Might look into it.
30-10-2007, 11:10 PM | #21 | ||
Young !@#$ Head
You could just have a dirty throttle body which will make it idle rough... have you had the battery out for a period of time lately by any chance???
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
31-10-2007, 02:18 PM | #22 | |||
Formerly MR BAXR6t
31-10-2007, 10:17 PM | #23 | ||
Young !@#$ Head
No idea then. My Ser 3 Xr8 idles a little rough but nothin serious. Its done just on 200,000 k's
Edit: Some times if you clean the throttle body your computer will still think its dirty and wont compinsate for the extra air coming in. So maybe reset the computer. There is a way to do it but i dont know it. Taking the battery out will reset it if you leave it out for more then 40 min i think. Can anyone else confirm this
Thread Tools | |
Display Modes | |
