forgot to add ,,
its a 2002 focus lr lx , with 2.0 liter zetec auto .. |
What exactly are you referring to mate?
the brass threaded nut ,,
below the green fuse. |
Does it have any wires running to it, if so, where do they originate from?
Maybe a temperature sensor ?
Looks similar to this, although I would expect this would be fitted into the inlet manifold or block somewhere ?
http://www.ebay.com.au/itm/New-Genui...-/150984176475 Last edited by Russ; 24-04-2013 at 09:02 AM. |
It's an under-bonnet air temp sensor to activate the engine cooling fans to run on after the engine has been switched off. This was the early fix to prevent fuel evaporation and poor hot engine starting. Fans were only activated at very high under-bonnet temps.
cheers p.laver ..
just seemed odd that its just sitting there ,, and a thread on it . |
Yes I know it's odd, some things are when they are introduced in a rush!!!
2012 Focus ST Tangerine Scream |
Thread Tools | |
Display Modes | |
