Ok guys, I have a stereo/hi fi out in the shed and the radio reception is terrible. It currently just has a single wire for FM and a loop for AM. How can I improve reception, moreso on FM? Is it possible to use a car antenna? I went into a local electronics shop and they pretty much said there is nothing.
A set of rabbit ears should do the job. $5 from your local cheap as chips shop. They are VHF so work OK on the FM band. Just make sure you also get a pal female - female joiner as well.
^^^^thanks, I'll also give this a go as I'm suffering the same problem
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
Thanks for the tip. How do I attach the rabbit ears? To attach the existing wire you just push it in and flip the little clip over to hold it. There are 2 of them for both FM and AM (4 in total) but the FM currently just has the wire in one of them.
I can post a pic later if that doesn't make sense. |
64 Deluxe 4 door
![]() Join Date: Jun 2007
The 2 connections for fm.. designed for coax cable. Inner conductor and braid. Chop chop on rabbit ears and use the inner and outer. I have a purpose made fm antenna for my shed radio, bit like a large tv antenna. An old vhf tv antenna would work too.
XM Deluxe FG XR50 BA Pursuit Ute |
playing in my big shed
i had no radio reception at all inside my new house so i fitted a $19 car antenna to the roof with standard TV coax cable. tandy shop had a conector that i used to join the small coax from the antenna to the larger coax. tv coax goes to a normal tv wall socket and a lead from my sterio to the wall socket.
i have a panasonic sterio that has a provision at the back for a tv style antenna plug.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch `10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim. `04 BA RTV tray back, Red, V8 auto, `04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim. `03 BA XLS ute . Acid Rush, factory lpg, auto, `48 TEA20 Grey Ferguson, `62 Willys 6-230 , 4x4 light truck `04 Yamaha TTR 250 |
Performance moderator
![]() Join Date: Feb 2005
If antenna can be outside it'll work better.. Esp if steel shed ..
Thanks for the tips guys. Dad recently pulled down a TV antenna so I permanently borrowed it for an experiment. I just tried it and the reception is much improved even with the antenna just lying on the bench in the shed. So looks like I will stick it up outside somewhere.
Thanks again! I have no idea what the guys at Dick Smith and another electronics shop were on about. They said there was nothing to really do it with. |
3 users like this post: |
#9 | |||
option 2 - antenna often seen on 4x4's with a spring base, attach to the outside of the shed |
All Ford Club Life Member
![]() ![]() Join Date: Aug 2005
A VHF antenna is perfect for the job, most will comfortable do a range of 30 to 300Mhz
The FM range is 87-108Mhz Begin that the shed is a big metal box, mounting an external AE is the natural option. Old coaxial tv cable is also well suited for the job, use the centre core and only connect the shielding at one end, ie the AE end.
Worked AU XR8 Ute - Toy Std FG XR6T Ute - Daily Supercharged BA 6 Ute - Wife's daily 351W F150 93 XLT 4x4 Supercab |
#11 | |||
Simple antenna such as these - http://www.ebay.com.au/itm/SPRING-BA...-/251011892996 are easy to fit, cheap and work well. |
Thread Tools | |
Display Modes | |
