I was sure this has been covered many times, but i was unsuccessful in my search. So if anyone has a link or two, that would be awesome. I figured since I am looking to buy one I would find out. Is there any mechanical difference between the 200kW and 220kW XR8 motors?
Evan |
not here much anymore
Mechanically they have a different cam (from memory the 200 cam is actually bigger than the 220), and the heads and inlet manifold were tickled a bit by Yella Terra, but nothing too huge, and the tuning is a bit different. Otherwise they're the same.
RAM 1500
Oh, so its not just different mappings and an exhaust upgrade as i have been told? Does that make the 220 that much better or is it much of a muchness anyway?
#4 | |||
RAM 1500
Club Moderator
![]() Join Date: Dec 2004
i had the same problems when i was looking for an xr8. in the end i went for the 200kw au2 cauz it had less k's and had more options.
as for the differences as b2tf has said, its cam, roller rockers 200kw has 1.6 FMS as where 220kw has 1.72 yella terra ones. the 200kw has a 65mm t/b as where the 220kw has a 70mm. and then yella terra did some slight port matching between the bottom manifold to the heads. (which has also been said isnt anything special) the 220kw motor also got an engine oil cooler. i have a mate that works for ford parts and we checked the factory fuel regs, headers and cats and they are the same part numbers for both motors. and of course the 220kw will have a different tune in the ecu |
#6 | |||
RAM 1500
Interesting you bring it up, I just came across an old Wheels magazine (Sept 2001) the other day which has an article detailing exactly what Tickford did to the 200kw motor to get it to 220kw, right after their article comparing the 220 XR8 to the VX SS (it smashed it, by the way!). It was a great read, and contrary to the above apparently they do modify the fuel pressure regulator to deliver more fuel.
Thanks heaps guys. Sounds to me like it would be worth hanging out for a 220kW version then. I would only be looking at changing the exhaust and getting an edit, so it would work out better. I guess having an oil cooler the 220 would also last longer as well. Just got to keep my ear to the ground, as i do want a manual and they would sell fairly quickly.
Evan |
#9 | ||||
Club Moderator
![]() Quote:
![]() Classic AU - if you only plan on doing an exhaust and an edit then yeah i would wait for a 220kw motor. When i bought mine i went for the one with more options cauz i new that i was going to change the cam / RR in time. also have changed the t/b and added the oil cooler and that type of stuff. |
Can anyone describe what the engine oil cooler looks like. Im certain my motor is the 200 kw version but it has a tiny little radiator out the front which i can only think would be an engine oil cooler. The car is manual so it shouldnt be for the transmission.
#11 | |||
RAM 1500
#12 | ||
Ok im pretty sure it has an AFL 1 which I think is the equivalent to a Z9. Any idea what the cooler would be for?
Here is a photo. Couldnt get a better shot as car is parked up close to the wall.
#14 | |||
Club Moderator
#15 | ||
while reading this thread i have noticed the constant reference to headers/extractors, just how much difference in kw's do they make over the factory items?
my Fairlane is an AU2 so it should be the 185 kw i think and i would like to bump it without ripping the engine down. |
#16 | |||
Back on the road
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#17 | |||
RAM 1500
#18 | |||
RAM 1500
#19 | ||
Afterburner + skids =
Just while we are on the subject, is it correct to assume all 220's had the signed build plate on the rocker cover as well?
#20 | |||
Evan |
#21 | ||
Do you feel lucky?
Didn't YT put bigger valves in the 220 heads?
#22 | |||
Club Moderator
200kw is inlet = 46.7mm exhaust = 39.2mm 220kw is inlet = 49.3mm exhaust = 39.4mm |
#23 | |||
RAM 1500
#24 | ||||
Back to Le Frenchy
#25 | |||
RAM 1500
#26 | |||
With da Warlords
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
#27 | ||||
Back to Le Frenchy
#28 | |||
#29 | ||
Sorry to bring this back up again, but i have another question. What year did Ford start with the 220kW motor? Was it only 2001 or did they pu them in late 2000 model XR8's as well?
Evan |
#30 | ||||
Back to Le Frenchy
Thread Tools | |
Display Modes | |
