#31 | |||
LPG > You
#32 | ||
And someone correct me if I'm wrong but aren't all Ford V8 supsercar engines since the introduction of the V8 rules Wheezers?
#33 | ||
Yes they are... Not much in common with road going wheezers though!
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
#34 | ||
FORMERLY TX3DUDE
Fords in v8sc use a motorsport block not the road car block.
#35 | ||
Grinder+Welder = Race car
But that'd never win you a race in the pub!
351W was a pretty good truck motor anyway.... |
#36 | ||
Well naturally, would you spend $100,000 on an engine and use a $500 block?
#37 | ||
rocknrolla
its still the same block, just made stronger and the cylinder walls thicker to cope with lots of re-bores. they have big port alloy heads too. the inlet manifold is the biggie, totally different to a road car setup.
#38 | ||
funnily enought those heads are closer to clevo's than windsors....
#39 | ||
rocknrolla
yeah they are massive ports. the inlet manifolds resemble nothing road-going though, they run an offset distributer they're so big. i think they used to run the injectors outside the manifold too, do they still do that?
#40 | |||
#41 | |||
#42 | ||||
Boss 290 BA GT Goodness
Member of the FPV & XR Owners Club of ACT Web Links To Check Out Shannons Club Garage Facebook Photo Albums |
#43 | |||
Peter Car
#44 | ||
Well guys, I am putting a 351 Windsor into an EL, so at least there will be one on the road, finally.
#45 | ||
-Village Idiot-
I comtemplated it also aye.
Should bolt straigh ontot 5L mounts... the 351C's do, and i think the stud patten for the bell housing is all the same aswell. Should be fun, loooots more torque! ![]() |
#46 | |||
Just going back to the Boss/SVT Cobra R engine comparo, the research I've done the Boss 5.4 Block is a F series truck block, where as the 5.4 in the cobra R was a limited run, they used specific casts for them which are design to only be used a certian amount of times, then throw em away. I found this looking on one of the US sites. Agree about the 351w, much stronger block standard and the bolt pattern for the auxileries and bell housing are the same. Been thinking about doing this to my EB XR8, but getting an XB coupe shortly. There goes the funds for that upgrade
FM Mustang GT, manual - Daily driven Live, Love, RACE SOLD: AU III XR8 Quote:
#47 | ||
Bear with a sore head
I remember reading in a US magazine that said the SVT Cobra R block was from a Lincoln Navigator which I thought was the same as the F-Trucks?
#48 | |||
Peter Car
