WIK13D
was shoping today went out to my ute and it wouldn't start well it would start run like a dog for 5 sec and stop do you recon it is a fuel pump, or filter. it seemed to be getting hard to start b4 this happened. also how do tou change the fuel pump? i'm going to attact it tommorow.
W Pursuit
Check the filter first.Thats easier to change and MAY be the cause,you dont want to pull your tank out to pull the pump out for fun!!!!! Check your TPS too as this contributed too hard starts in my XR6 but who knows. |
WIK13D
sorry for my ignornce what is TPS i checked the relays
throttle position sensor
WIK13D
cheers i dont think its that but cause it still starts kinda if the throttle is depressed it wont fire at all i was told.
Commercial Sponsor
easiest way to do a fuel pump in a AU or BA ute is to remove the tub liner
then undrill the spot welds in the floor panel above the fuel tank. bend floor up carefully , remember you need to put it back down!!. so be neat! change fuel pump (and check the plugs as they can fail aslo) then bend floor back down and rivet back into place, replace tubliner and your done this way it can be done in about 1hr and you dont need a hoist. |
WIK13D
thankx i'll remember that for next time i did it the hard way. Which worked out ok cause the tank was full of rubbish. the hard way is remove exhust, remove tailshaft, undo axle U bolts slide axle back so the tank would clear every thing took me 5 hrs all up. your way sounds lots better
WIK13D
you wouldn't beleave it my ute bailed me up again it,s doing the same thing well nealry it started went about 5m then stoped but this time it wont fire any ideas please help
![]() Join Date: Dec 2004
Did you use any fuel hose inside the tank to attach the new pump? If so possible wrong hose was used.There is special hose to be submerged in fuel,ordinary EFI hose will swell...Just an idea....
WIK13D
i used a stock pump so it all just cliped in the existing pipes etc
Ok ,just a thought.Is the pump working ,when you first turn the key on for a few secs?
#12 | ||
you haven't crushed a fuel line under the ute have you?
MR INCH
#13 | ||
WIK13D
i got in it this morning and i started. i went up the road and it stalled (it's a auto) got it to go again but it was running ruff. i had to go to work so i left it got in it this afternoon and it ran like a dream any ideas. remerbering i neilry flatenerd thebattrey yesterday trying to start it after it stoped
