Old 22-04-2005, 05:29 PM   #1
TRBOETR
Huge Fatty
TRBOETR's Avatar
Default AU console shroud removal
I am trying to remove the centre console shroud to get to the factory head unit. I have followed the instructions on fordmods.com, but cannot get the shroud past the bottom 2 clips. I feel like I'm going to break it off. Has anyone done this before that can lend a hand?
Cheers.
TRBOETR is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2005, 05:40 PM   #2
TRBOETR
Huge Fatty
TRBOETR's Avatar
Cancel that... Tore the **** out!!! hehe
Old 23-04-2005, 01:07 AM   #3
12
Silhouette AU1 TS50.
12's Avatar
Did you know you can remove the headunit without removing the centre console? See the two holes on each side of the HU? You need a U shaped tool (made out of a coat hanger even), then all you have to do is push it into the holes and pull the HU out. Oh.. too late now.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2005, 06:09 PM   #4
TRBOETR
Huge Fatty
TRBOETR's Avatar
Yeah idid figure that out, but after I pulled off the front of the HU, the right hand side of this quick release thingy was broken off!! I figured that was what the holes were, juts couldnt use them!! I got the HU out without touching the console, so its all good.
Old 28-04-2005, 09:22 PM   #5
5speedTE
5speedTE's Avatar
hey guys, i tried this coat hanger thing with the two holes, it dont seem to wana come out. Is there a special way to do it?
5speedTE is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 09:43 PM   #6
cArSiK
i find the easy way is to put your hand underneath the console and pushing from the back of the head unit with the coat hanger inserted.This will allow it to slide out straight away....it takes me about 10 seconds now , it used to take me hours to get it out....
J
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2005, 11:57 PM   #7
12
12's Avatar
Originally Posted by useless
I have a set of security keys to remove the radio .It normally takes 10 seconds.
Useless, could you possibly take a pic of the tool, say.. next to a ruler so we can get an idea of what it looks like please?
PIC'S OF MY
T1 TS50.
Old 29-04-2005, 12:01 AM   #8
Kryton
Kryton's Avatar
the dimension are in your garage manual. you can make them from this. 2 bits 3mm wire bent around to a U shape (one for each side). doesnt matter how long it is so long as you can get both ends in all the way. when you have hit the bottom then pull the left one left and the right one right as you are pulling it out. if that doesnt work then pull the left one to the right and the right one to the left as you pull.
presto! a stereo in you hand in 10 seconds.
Old 29-04-2005, 02:06 AM   #9
blackers10
blackers10's Avatar
now the question is.. how do you mount the aftermarket single din Headunit?
and how much do ford charge for the filler pocket?
cheers fellas
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2005, 07:19 AM   #10
pommy30
PommyAUIIIXR6
Just duck into ford and if the service guys aren't ****ers they'll usually pop it out for you took them all of 10 seconds for mine. As for mounting the single din headunit it's not that hard just think outside the square and you'll be fine. Unsure how much ford charge for the filler pocket but you'll be able to get one from a decent audio shop, depending on what style you want, i.e. just a plan pocket or pocket with cup holder etc you'll be looking anywhere from $35 to about $80 :sm_headba
Pommy, AUIIIXR6 Alpine sound,K & N Filter Rebel Body Kit and let the mods begin!!!!!
pommy30 is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2005, 05:03 PM   #11
|2aebird
Resident Volvo Driver
I paid about $15 for my trinket tray for under the single din unit...
|2aebird is offline   Reply With Quote Multi-Quote with this Post
