Monsoon SIII XR8 220
Hi all,
Got into car today and the stereo wouldn't respond to anything, just the red light for load on continuously. Am a bit reluctant to disconnect battery as I don't have the code. Any ideas? Cheers, Slymo |
Do you feel lucky?
It's probably buggered. Exact same thing appened to mine - one of the trays inside was broken.
You can get them fixed for a few hundred bucks, but once they start giving trouble they seem to keep giving trouble. Time to chuck it. Consider buying an Alpine or Pioneer unit that will let you control an iPod from the head unit. Leave the iPod in the glovebox - they connect up to the head unit by way of a cable running through through the back of the dash that also keeps them charged. Search this forum, there are quite a few threads on this. |
Just a follow up...
I bit the bullet and pulled the fuse, reinserted it then after a bit of stacker noise it asked for the code. Went to ford and got the code, voila! now working, though I am sure it will not be for long! Cheers Sly |
#4 | |||
Audi S3
mine did this the other day. and i got a flat battery on sunday. assuming from that light staying on 24/7. jumped the car- then got the battery replaced. i had to enter the code. but the radio came good. but says there are no cd's in the stacker when there are actually 6.
Hey HLC...
Have u tried taking out all cd's ripping out the fuse, re-entering the code and seeing if that works? Cheers, Sly |
#6 | |||
Audi S3
i jsut have to go back to ford and get it replaced under extended warranty. but im too damn lazy.
