Old 15-07-2007, 03:25 PM   #1
FS5
Default car won't start
i went out this arvo to go up the shops and the car won't start.i went up town early on in the morning and it was running fine.
i went to start it as i normaly do,and it just kept cranking over.its not even firing at at all.
the fuel pump comes on when i turn the key to start.i have checked all the leads and sensors and they are all connected.
its got me stumped ,they car ran fine now it won't start.could it be a fuse or something ?
any help appreciated thanks
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2007, 04:22 PM   #2
schuldiner
likely culprits are usually battery/starter motor or alternator. i know with my xf when i replaced the alternator i had trouble starting it and i stressed over it for ages, it would turn over but not fire. i switched it from gas to petrol put some carby cleaner down its throat and it started fine, not sure why it did that but it never happened after that maybe try start it on petrol(if you have dual fuel).
Everything always works out when you just do whatever you want and don't worry about the consequences.
see my ute here
AU parts for sale
schuldiner is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2007, 05:32 PM   #3
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
if its turning over its not your battery/starter motor, or alternator.
even though the fuel pumps runing you could possibly have a fuel blockage, or the pump motor may be spinning but not pumping ifits broken, also check to see if you have a spark - it could be immobilised, or it could be something simple like a loose wiring connection somewhere (maybe to the coil pack), or even a dicky/loose fuse or relay in the power box under the hood
$416.80.......All that cash came from a new (used) car. Check your back seats!
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2007, 06:53 PM   #4
schuldiner
ha ha true, my bad, forgot about it still cranking over.
see my ute here
AU parts for sale
Old 15-07-2007, 06:54 PM   #5
Stav
Smile
Stav's Avatar
Remove a lead and place it close to earth.See if a spark is jumping .Dont hold it though.Apart from that maybe fuel is not gettting into the rail?
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 15-07-2007, 07:42 PM   #6
robbo_yobbo
Kick out tha Jams
haha, been there, done that, I can safeley say never again!
Old 15-07-2007, 08:29 PM   #7
FGII-XR6
FGII-XR6's Avatar
you say the fuel pump is coming on but it can make all the noises it's meant to ans still be cactus best bet is find someone with an OBD code reader that will tell you whats wrong
Old 15-07-2007, 08:35 PM   #8
FS5
yeah ,that was next on my list.i'l have another fiddle in the mornin .i've had one hectic sunday arvo without a car(nik had us booked in for a family portrait).
when i turn the key to start the fuel pump whizzes for a bit until it builds up pressure ,so i assume its still working .
are there any sensors that would stop the motor from firing if they weren't working?
i don't think its the smartlock or whatever its called ,because the engine still cranks over.
Old 15-07-2007, 09:18 PM   #9
robbo_yobbo
Kick out tha Jams
there could be something thats come unplugged (coilpack or relays) , find out if youve got spark or not first, and that will help narrow it down.
also this may sound like a pretty dumb question, but is it out of fuel?
Old 16-07-2007, 09:10 AM   #10
FS5
Its got no spark, all the fuses are ok, relays are in tight, all leads and plugs are hooked up properly.
could it be the coil pack? the car has been running fine.
i was reading in the old haynes manual under trouble shooting and it suggested that there could be something wrong with the ignition switch??? when i turn the key to start all the norm dash lights come on.
Old 16-07-2007, 01:00 PM   #11
Morgz88
I've had the exactly the same problem before.
Turned out to be the 60A fuse in the engine bay.
Funniest thing was, the fuse LOOKED fine by visual inspection, lucky I checked it with the multimeter and realised it was blown.
Maybe worth a look for you just in case.
Morgz88 is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2007, 01:20 PM   #12
robbo_yobbo
Kick out tha Jams
check the power distro box and check the fuses are ok, grab out your multimeter, and see if there is power getting to the "START" relay when you turn the key, this will tell you which side the problems on. if theres no power getting to it and the fuses are ok, it might be a dash side wiring issue, (disconnected, or melted through) or maybe even the same problem in the power distro box
otherwise check to see that the wiring harness plug to the coilpack hasnt come out, and that power is getting to the coilpack.
Theres also the possibility the coilpack is cactus, but that would more likeley wear out over time.
Old 16-07-2007, 02:08 PM   #13
FS5
thanks for your help guys,i bit the bullet and got a mobile mech to come out.$230 later and the problem is fixed.it was the crank angle sensor.these guys sure know how to charge $120 to come out and 110 to plug the scan tool in .but at least its fixed now.
a couple of other codes came up on the scan tool P3381 and P0000.i tried looking them up in the haines manual but it dosen't have them listed.if someone knows what they are or where i can find out what they are i'd apreciate.
Old 16-07-2007, 02:19 PM   #14
FGII-XR6
FGII-XR6's Avatar
for $230 i'd be ringing them and asking what the codes mean thats a fair slug
Old 16-07-2007, 11:39 PM   #15
Mechan1k
Mechan1k's Avatar
I know my mechanic has a listing of these codes with high Snap-on scantool for the AU.
Although by the time i get the codes for you ... someone else will post it up.
Old 17-07-2007, 01:03 AM   #16
waggaclint
waggaclint's Avatar
i think youl find those codes dont even exist hey dont no were ya mechanic got them from..
listed hear is all the codes
FORD FALCON AU 4.0L (H, S, X and Y Engines) 1998-02 Engine Management System
FORD FAIRLANE AU 4.0L (H, S, X and Y Engines) 1998-03 Engine Management System
FORD LTD AU 4.0L (H, S, X and Y Engines) 1998-03 Engine Management System
(Includes Factory LPG Systems)
Go To: INDEX Go To: COMPONENT LOCATION Copyright Ó AUTO-TECH
Fault Codes
OBDII Fault Codes can be accessed only with an OBDII Compatible Scan Tool.
Fault Code Erasure
Fault Code Erasure can be carried out Only with an OBDII Compatible Scan Tool.
Fault Code Extraction
Fault Code Extraction can be carried out Only with an OBDII Compatible Scan Tool.
Fault Code Table
Code # Circuit and Status
P0106 Manifold Absolute Pressure Sensor (T-Map)
Out of Range
P0107 Manifold Absolute Pressure Sensor (T-Map)
Low Voltage
P0108 Manifold Absolute Pressure Sensor (T-Map)
High Voltage
P0111 Intake Air Temp. Sensor
Out of Range
P0112 Intake Air Temp. Sensor
Low Voltage
P0113 Intake Air Temp. Sensor
High Voltage
P0116 Cylinder Head Temp. Sensor
Out of Range
P0117 Cylinder Head Temp. Sensor
Low Voltage
P0118 Cylinder Head Temp. Sensor
High Voltage
P0121 Throttle Position Sensor
Out of Range
P0122 Throttle Position Sensor
Low Voltage
P0123 Throttle Position Sensor
High Voltage
P0131 Exhaust Gas Oxygen Sensor
Low Voltage
P0171 Fuel System too Lean
Air Fuel Ratio too Lean
P0172 Fuel System too Rich
Air Fuel Ratio too Rich
P0201 Injector #1
Circuit Malfunction
P0202 Injector #2
Circuit Malfunction
P0203 Injector #3
Circuit Malfunction
P0204 Injector #4
Circuit Malfunction
P0205 Injector #5
Circuit Malfunction
P0206 Injector #6
Circuit Malfunction
P0230 Fuel Pump Relay
Malfunction
P0263 Cylinder #1 Balance Test
Failed
P0266 Cylinder #2 Balance Test
Failed
P0269 Cylinder #3 Balance Test
Failed
P0272 Cylinder #4 Balance Test
Failed
P0275 Cylinder #5 Balance Test
Failed
P0278 Cylinder #6 Balance Test
Failed
P0320 Engine Speed Circuit
Malfunction
P0325 Knock Sensor
Out of Range
P0327 Knock Sensor
Low Voltage
P0340 Camshaft Position Sensor
Malfunction
P0350 Ignition Coil
Failure
P0351 Ignition Coil #1
Failure
P0352 Ignition Coil #2
Failure
P0353 Ignition Coil #3
Failure
P0443 Canister Purge Solenoid
Malfunction
P0480 Electro Drive Fan #1
Malfunction
P0481 Electro Drive Fan #2
Malfunction
P0500 Vehicle Speed Sensor
Malfunction
P0506 Idle Air Control System
Idle Speed Low
P0507 Idle Air Control System
Idle Speed High
P0531 A/C Pressure Transducer Sensor
Out of Range
P0532 A/C Pressure Transducer Sensor
Low Voltage
P0533 A/C Pressure Transducer Sensor
High Voltage
P0534 A/C Refrigerant Charge
Low
P0562 Battery Voltage
<9.0 Volts
P0603 Keep Alive Memory
Test Failed
P0605 PCM Read Only Memory
Failed
P0606 PCM Control Processor (CPU)
Failed
P0706 Transmission Range Sensor
Out of Range
P0707 Transmission Range Sensor
Low Voltage
P0708 Transmission Range Sensor
High Voltage
P0710 Transmission Fluid Temp. Sensor
Out of Range
P0712 Transmission Fluid Temp. Sensor
Low Voltage
P0713 Transmission Fluid Temp. Sensor
High Voltage
P0743 Lock Up Solenoid #7
Failed
P0748 Variable Pressure Solenoid #5
Failed
P0753 Shift Solenoid #1
Failed
P0758 Shift Solenoid #2
Failed
P0763 Shift Solenoid #3
Failed
P0768 Shift Solenoid #4
Failed
P0778 Power Control Solenoid #6
Failed
P1125 Throttle Position Sensor
Circuit Noisy
P1156 Fuel Select Switch was NOT Manually Switched during LPG Test.
P1159 LPG Stepper Motor
Failure
P1167 Operator did NOT actuate Throttle in Self Test. (Goose Throttle)
P1182 Gas Cut Out Solenoid Relay
Malfunction
P1221 Traction Control
Malfunction
If DTC P1221 is displayed, First check if the Vehicle has Traction Control Fitted.
This DTC can show on any Vehicle with or without Traction Control.
P1259 Engine Enable Input (Smartshield)
Malfunction
P1260 Vehicle Immobilised
Smartshield Detected Theft
P1347 LPG Gas Tank Level
Out of Range
P1348 LPG Gas Tank Level
Low Voltage
P1349 LPG Gas Tank Level
High Voltage
P1358 Distributorless Ignition System
Failure
P1370 Engine Speed increase during spark advance test
Too Low
P1380 Variable Cam Timing
Failed
P1433 A/C Refrigerant Discharge Temp.
Low Voltage
P1434 A/C Refrigerant Discharge Temp.
High Voltage
P1435 A/C Refrigerant Discharge Temp.
Out of Range
P1436 A/C Refrigerant Evaporator Temp.
Low Voltage
P1437 A/C Refrigerant Evaporator Temp.
High Voltage
P1438 A/C Refrigerant Evaporator Temp.
Out of Range
P1463 A/C Pressure Transducer Sensor
Low Pressure
P1464 A/C Turned ON during Self Test
P1465 Air Conditioner Relay
Malfunction
P1471 Electro Drive Fan #2
Failed
P1472 Electro Drive Fan #1
Failed
P1520 Intake Manifold Runner Control
Malfunction
P1535 Blower Fan Speed (Heater Fan)
Out of Range
P1650 Power Steering Pressure Switch
Failure
P1651 Power Steering Pressure Switch
Didn't change state during Self Test
P1653 Power Steering Pressure Switch
Malfunction
P1654 A/C Recirculation Override
Malfunction
P1655 Starter Disable
Malfunction
P1705 Not In park or neutral during self test.
P1768 Power Economy Switch
Failure
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2007, 02:18 AM   #17
FGII-XR6
FGII-XR6's Avatar
yes thats the same as the list i just found so it sounds like a it doesn't exist
Old 17-07-2007, 12:00 PM   #18
robbo_yobbo
Kick out tha Jams
good to hear its solved, things like this is why I want one of those scanners.
On that note, does that mean the OBDII scanners on eBay will do the trick? is there anything in particular to look for to make sure thier compatible?
Old 17-07-2007, 12:39 PM   #19
FGII-XR6
FGII-XR6's Avatar
as I understand it they use a different protocol so no they won't
Old 17-07-2007, 03:09 PM   #20
james22
With da Warlords
james22's Avatar
damn, i'm chasing a scanner too, no body seems to be able to give a straight answer on what will and wont work.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2007, 03:55 PM   #21
robbo_yobbo
Kick out tha Jams
I know the feeling
Old 17-07-2007, 04:51 PM   #22
FGII-XR6
FGII-XR6's Avatar
I'm chasing ford for the specs but it's like pulling teeth
Old 17-07-2007, 05:00 PM   #23
robbo_yobbo
Kick out tha Jams
anyone know a dentist???? lol
Old 17-07-2007, 07:47 PM   #24
FS5
waggaclint, thanks for posting the codes mate.
yeah i was a bit suss about the codes. my car still runs a AU II SI ECU (S Pac). when he put the tool on he typed in AU I Futura so maybe that's confused some thing some where. i quizzed him about it but mechanic's know best.
so i guess there is some thing else to look for when your au will crank over but wont start
Old 17-07-2007, 11:41 PM   #25
waggaclint
waggaclint's Avatar
not to sure about the scan tools on ebay...i use a otc one at work there about $5000...but as far as i know it just needs to be obdII compatable ill see if i can find out any more for you guys....i know you can get small ones that just read codes for a few hundred a tool guy came into work the other day sealing them and he reckons they work ill find out what brand they were...
