#31 | |||
LPG > You
And yes, an auto XR6 will easily beat an auto SP23. They're capable of better then 15.4. Motor had the auto BA XT listed as 15.28, and that's a car with a worse diff ratio, less grip etc. The XR6 is capable of at least the same performance... with the 3.45:1 diff making up for its 16kg weight gain (1688 vs 1672kg)... possibly even making it faster then the XT.
LPG Lovers Association President & Member #1. ![]() ![]() |
#32 | |||
LPG > You
Now if your Fairmont is an 8... that's a whole different kettle of fish.
#33 | |||
1999 Ford Fairmont Ghia
There are many papers on the subject and it simply comes down to the age old saying that "there aint no replacement for displacement" simplya 15% increase (exhaust) to the SP23 is going to equal an increase of 17kw while an increase by 15% to my Fairmont is going to equal 25kw. If you graph modifications on top of each other with the Fairmont against the Mazda you will find that the horsepower will increase sharper in the Fairmont as it is coming off a stronger base torque wise. Sorry if I'm not being clearer but it is difficult to explain. If you give me 10 grand and a SP23 I will explain ![]() Also while the Mazda has a strong raw acceleration figure this does not tell the whole story. From my own experience my Fairmont beat a TX3 Turbo in an uphill race . My theory is that since the Fairmont had a shorter and meatier torque curve it could roll on the power better coming out of slow corners...or maybe the TX3 was cactus.......either way the Fairmont felt fitter. Not bagging SP23's either I am a big fan of them and wouldn't mind adding one to my garage. |
#34 | |||
LPG > You
Stock on stock an AU Ghia with the VCT engine mops the floor with TX3 Turbo's. That's an early 90s/late 80s turbo 4-cyl that once made just over 100kW and today wouldn't anymore (age plus owner demographic who... don't take the best care) against a new, late model car.
#35 | ||
Righto but don't discount that the TX3 only weighed 1000 kilos giving 10kg/kw while the SP23 had a similar 10.4kg/kw.
The TX3 is a very fun drive bet your right I won't know until I try. But on a similar note I have cleaned up a Corolla Sports model and Camry Sportivo but knowing Toyota they probably weren't REALLY sporty. |
#36 | |||
LPG > You
The old shape had the 112kW 2.4L 4cyl or 141kW 3.0L V6 - again, just a bodykit. The Corolla "Sports," had the same 100kW 1.8L 4-cyl as every other regular Corolla. If its a Sportivo, however, it shares the 141kW 181Nm 4-cyl 1.8L engine with the Celica and Lotus Elise/Exige. That one would hose a 6cyl AU Ghia. The normal "Sports," one can't get out of its own way. ![]()
#37 | ||
149 rwkw of Style
The result is in...0 -120 k's ..XR6 won easily by 3 car lengths...case closed!
Thank you for all your opinions.
2004 XR6 Mercury Silver |
#38 | ||
I hope you had money riding on it or at least got a beer out of it........
#39 | ||
There is no way in hell an auto SP23 will run those times people have been throwing around...its lucky to run a 16.
This thread made me lol. Thank you.
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
#40 | |||
#41 | ||
What a performer!
I don't think the SP23's are really fast at all. My Laser is just a tad slower than a SP20 Astina.. and my Laser isn't all that fast.
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
#42 | ||
It's because small cars FEEEELLLL fast.
I remember being in a mated Daihatsu Charade and going wow this thing is flying and then looking at the speedo and seeing it's only doing 50 kays. The Daihatsu felt at 50 kays what my Fairmont feels at 150 kays. I used to think my KF Laser was super quick (didnt help that it blew off Commodores) and then I stopwatched and it struggled do do sub 10 seconds to 100 kays. Bloody Ricers |
