29-08-2007, 08:12 AM | #1 | ||
at the moment my 1994 Ford Telstar Ghia , is loosing oil and some water , it smokes a fair bit when i start it up ,when i drive not much at all , i possible may need a new motor , but at the moment cant afford one, is their something that i can put in with the oil that will stop the smoke comming out of the exaust system , it always looks bad when i start it up when cold expecialy
thanks for any help |
29-08-2007, 09:33 AM | #2 | ||
Back where I belong
Sounds a lot like you may have done a head gasket mate, thats about the extent I can think of.
Regards Craig |
29-08-2007, 01:44 PM | #3 | |||
cheers |
29-08-2007, 03:59 PM | #4 | ||
yep, sounds like a head gasket. Check the water in the radiator, is it all creamy?, if so it means the water and oil is mixing together.
A good mechanic will be able to tell you straight away if it's a head gasket. If you keep driving it you will do more damage, will cost a bit to fix too, depending on the mechanic. Any where from a few hundred (getting a mate to do it) and having the head replaned if it's not warped to over a grand for a professional job. He'll probably recommend getting the valves redone whilst the heads off if needed. If you are OK with a spanner you could have a go yourself but it requires being done properly, making sure the heads OK , that you get all the old gasket off, fine grit sand paper on the block to make it nice and clean, torquing down the bolts to spec etc.
jaydee351 4DV8 |
29-08-2007, 06:38 PM | #5 | ||
What a performer!
Get a CO2 (?) test at a mechanics a cheap $20 way to find out if you've done your head gasket.
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
29-08-2007, 07:15 PM | #6 | ||
Thanks for the info
09-09-2007, 08:43 PM | #7 | ||
Injected
The fact that it only smokes wen u start it points 2 valve guide seals. There alot cheaper 2 repair than a head or head gasket. The water loss could b from alot of things, as jaydee said check the water, if it is clear than it is more than likley that the oil and water are unrelated.
