Sly like a G6
Just as the Raptor kit nears completion, my old bus is starting to consume oil with 330,000km up.:gren: Looks like I'll be needing to do some sort of rebuild or engine swap no matter what.
So I'm idly thinking, why not put a V8 in it? A quick search reveals about 3 relevant threads with not a lot of info. Of the 3, one basically says "buy a V8 Fairmont" and one is still a work in progress. I won't necessarily need an XR8 V8 to start with. I'm thinking engine, gearbox (mine is still original), looms and PCM. Any Smartshield PCM should be able to talk to my AU1 Smartshield BEM once coded? And will I need K-frame and other hardware? Then build it with a 347 stroker kit, mild cam, heads and Explorer intake before fitting. Bear in mind it's a wagon, so selling it to buy an XR8 isn't an option. I need the rear headroom and luggage space. Any thoughts/advice?
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
talk to chief ..wasnt he building a stroker wagon??
your other option may be a 4.8 stroker for the 4ltr ... could go VERY nicely with the supercharger kit!
Rebuilding the ED
A guy just down the road from me wrecked a s1 au xr and put all the front and running gear into a s3 wagon, had to change dash, steering column the lot.
If you want ins and outs pm me and i will find out.
ED XR8 In for a rebuild 347 Dart block:All the Scat goodies, Edelbrock Victor Jnr's, Trickflow manifold and Vortech on the stand/ work in progress ![]() |
#4 | |||
Sly like a G6
My engine mightn't last that long as it's gone from using 300ml or less between fills to needing 2 litres before the last change. It has the obligatory oil leak around the cam chain tensioner but I doubt that much is coming out of there. Bummer really, the compression was spot-on at the end of September... will have to check it out again at the weekend.
could always run E series bottom end and get some custom pistons.. apparently they arent all THAT expensive..
or see what atomic can knock you up
#6 | |||
windsor user
www.TUFFCARPARTS.com
If you're seriously considering a V8 conversion, my advice would be to either sell it and find a V8 Fairmont wagon, or buy a smashed donor car. Buying parts individually can get very pricey very quickly!
#8 | |||
#9 | |||
windsor user
#10 | |||
Sly like a G6
I think the change over was towards the end of series 1.
#12 | ||
before october 99
as debs lane is S1 and it has smartshield (flashing hand on the dash) where as my march 99 au lane has no hand .. also we have different shaped keys.. mine are the EL shape with a sausage shape cutout at the top of the key for the keyring to pass thru debs is an L shape in the corner of the key.. and her key is fatter most people refer to the smartshield equiped au1s as au1.5's
#13 | ||
windsor user
well there ya go, learn something new every day
#14 | |||
Sly like a G6
#15 | |||
Sly like a G6
I might have a chat to FTG. They're far from the cheapest but I suspect that spending a little more there would be money well spent. A V8 Fairmont wagon would be nice, if I could be sure it hadn't had the guts flogged out of it towing horse floats. At least I know how mine's been treated.
#16 | |||
#17 | ||
fordpro at smithfield should be able to help or macarthur parts plus also we have 2 falcon specialists here wickham spare and hunter falcon centre which one were you referring to ( i think i can guess )
[SIGPIC][/SIGPIC]
#18 | ||
Sly like a G6
I've never been able to find HFC LOL!
BTW are you still in touch with Tim the Raptor man? He's hit some snags tuning the Intech for boost :( but the VCT engine seems to be fine. I'm thinking maybe to drop a VCT conversion in. It's only a small premium over a like-for-like replacement, and probably cheaper than rebuilding my original donk. Not to mention that a VCT engine conversion + Raptor kit is probably half the price of a V8 conversion + stroker build.
#19 | ||
vct is only a head and some wiring and and ECU... which being ford.. its all there just not plugged in..id say
#20 | ||
Sly like a G6
By "conversion" I mean complete engine, loom & ECU. Given the sudden increase in oil consumption that triggered this thread, a complete low-mileage engine is probably not a bad idea...
#21 | ||
The Destroyer
i got a explorer manifold for sale. pm me if your intrested
Toy- Blown XR8 Ute. Black on black "Front-drive cars are for children" |
#22 | ||
Sly like a G6
Just sitting tight ATM while I see if a boosted VCT 6 transplant is a viable option.
#23 | |||
I would personally think for all the effort, the VCT conversion wouldn't be particularly worthwhile once it's boosted anyway. |
#24 | |||
