Old 19-11-2008, 12:46 PM   #1
Twinpiston
Finally rollin on 20's
Twinpiston's Avatar
Default Water Under Rear Seat
This seams to be a theme with me at the moment.
I just lost one of my seat belt clips down the back seat (3 door) and so lifted the seat to grab it back and noticed some water sitting above the carpet line. Where is this coming from, are their holes that are not sealed?
Any info greatly appreaciated.
Fiesta ST..... Colorado Red...... SOLD
Territory Turbo Ghia ..... Winter White
SOLD - Good bye my little buddy!!!!
K&N, F6 Snorkel, Debung, 20" Enix Turbine in Gunmetal, 7 seat rear springs.
Twinpiston is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 01:58 PM   #2
robjh80
robjh80's Avatar
Never heard of that problem
Isn't your Fez brand new?
I'd be getting back to Ford asap to sort out if it is.
robjh80 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 03:09 PM   #3
Twinpiston
Twinpiston's Avatar
Second hand with 7 months left!!!
Old 19-11-2008, 05:22 PM   #4
kiwijohn42
Death B4 Decaf
kiwijohn42's Avatar
Do you have children?
Is there something they haven't told you?
06 fiesta Zetec in Tango. Factory scuff plates, mats, spoiler & leather gear knob. K&N panel filter. Focus clear side indicators. Colour coded.
kiwijohn42 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 07:34 PM   #5
Argh-Ess
'07 Fiesta Lx
I had a leak in mine not too long ago. the boot carpet was wet, so i dont know if its the same place the water is getting in. Mine was leaking from where the taillight screws into the plastic clip, if that makes sense. Its a pretty common fault on Ls focus.
Argh-Ess is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2008, 12:29 PM   #6
theostheone
TwinPiston,
Had the same problem.
When it rains sometimes water gets in the doors in the gap between where the glass seals with the doors, or if you have your window open when it rains water gets into the gap where the glass goes into the door, and this can then leak into the car.
When this happens the cavity in the door fills with water. If you have a look under the door you will see the rubber seal that goes around the door. It has small holes in it to let the water run out when it gets into the door. Sometimes these holes become clogged and water accumulates inside the middle of the door, so much so that in some cases it can be up to about a litre or so (in my case) It can be heard when your driving swishing around. I would say that these holes are clogged and need to be unclogged with a skewer or something similar. This will allow the water to drain out of the bottom of the door and you shouldnt have the problem.
Theo.
theostheone is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2008, 01:25 PM   #7
Twinpiston
Twinpiston's Avatar
Thanks for that, only 1 problem with your theory, and I have heard that one before, I only have 2 doors and the water was sitting on the transmission tunnel (if we had a tail shaft)
Anyhow, the mystery goes on....
