Old 06-01-2009, 10:48 PM   #1
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Default Christmas pressie for the Focus
Apart from the usual excessive eating at Christmas, I actually did something quite constructive with the Focus.
Let there be light...(please excuse the grubby seats!)
I purchased the Focus light fitting off Ebay a while ago (around $65 from memory) and finally got the time to install it. It was secondhand from a car wrecker, but you wouldn't know it - you don't want to know the price of a new one from a dealer!!
Nice to finally see the floor in the back now. FYI - I have a Jaycar LED Globe in the front , normal globe in the rear - will be upgrading the rear one soon as well.
Link: LED Festoon Light Globe 12VDC 41mm
If anyone wants any daytime shots to see placement/etc, let me know.
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2009, 11:00 PM   #2
Blackfocus
A day time shot would be great if possible
05 SX GHIA Territory
08 Dual Cab XL Ranger
RIP 08 LT CL Focus
Blackfocus is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2009, 11:13 PM   #3
AnthonyTDCi
Focus TDCi
AnthonyTDCi's Avatar
oooh i like it!
i absolutely hate the fact that the LS/LT's dont have a light for rear occupants! probably my biggest pet peeve with my car.
how hard is it to actually wire in?
do you have a guide on how to do it? because i am very keen to do it!
anthony
AnthonyTDCi is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 01:03 AM   #4
819_FLY
819_FLY's Avatar
I would imagine you would wire it straight off the front light so when you switch on the front light the rear one illuminates aswell, or you could wire it up by itself so it operates totally independant.
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL
Check out 819FLY!!
819_FLY is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 01:26 AM   #5
RJO89
EuroFordClub
RJO89's Avatar
Would be easy as pie to wire in. The hardest part would be cutting the correct sized hole for it.
But to wire it in, grab a multimeter, pop the front light out, open a door and check to see which is +ve and which is -ve. Run a wire from each (16 gauge) through the roof lining and poke it out the hole that you have cut, then solder the connections into the new light. Bam, easy done .
Did the same thing for my rear lighting and footwell lighting!
'08 Black Ford Focus LT CL Hatch
Far from stock... --- SOLD :
Now riding a 2009 Kawasaki Ninja 250R :
RJO89 is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 11:05 AM   #6
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Yep, very easy to wire in. Didn’t quite go to the trouble of using a multimeter, but did the same as you mention (minus the footwell lighting). Cutting the hole was ok, just had to make it a nice tight fit. Getting the wire from front to rear was a little more challenging though.
Daytime pics to come in the next few days.
2006 LX FOCUS SEDAN
Old 07-01-2009, 11:28 AM   #7
Turbodiesel
Torquer
Turbodiesel's Avatar
The rear of the Focus is as dark as a bloody dungeon at night :P
That looks good, I like the LED light in the front as well.
Turbodiesel is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 11:49 AM   #8
FOCUSonTHIS
FOCUSonTHIS's Avatar
How do you know how dark a dungeon is?? Actually on second thoughts I don't want to know :P
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
FOCUSonTHIS is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 03:33 PM   #9
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Quote: "How do you know how dark a dungeon is"??
We'll have to ask the expert..........Zetec.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2009, 03:59 PM   #10
Turbodiesel
Torquer
Yeah you really don't... hahaha
Old 08-01-2009, 10:26 PM   #11
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Daytime shots as requested:
2006 LX FOCUS SEDAN
Old 09-01-2009, 06:57 PM   #12
AnthonyTDCi
Focus TDCi
yep im definatly going to have to do this mod. how much was the light from ford?
how is the light secured into the roof lining? or is it just sitting there?
Old 09-01-2009, 11:16 PM   #13
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
It was a while ago that I got the quote from a dealer, but pretty sure it was over the $150 mark...
The fitting has little tabs on one side, and a metal spring clip that holds it in place - its going anywhere. The good thing is its still relatively easy to remove the clear lens if you need to change a bulb.
Since buying mine, I have seen upper-spec (UK) model fittings that have reading lights in each side.
2006 LX FOCUS SEDAN
