Cat Lover
Hi everyone,
I have a hesitation on my 01 5sp Cougar that I just cant get rid of. The hesitation is down low, below 3400rpm. It gets worse if I press the pedal down further. Not so evident in the higher rpm's, the IMRC appears to work fine as I can feel a surge of power past 3400rpm. Work done so far: Replace Plugs Replaed Leads Completed Focus SVT fuel pump fix (As per NECO) Changed fuel filter Checked all plug gaps Vacuum leak tested (water bottle method) And for the life of me cant figure out what it is. I am thinking it may be coilpack but dont want to fork out money if not necessary. I am not getting a check engine light and I have checked to ensure the check engine light works..... Does anyone have a code reader/scanner they can hook up to my car to see if it is one lead/plug that is causing the hesitation in the Sydney area? Even if anyone is a mechanical genius that can help me diagnose it. Anyway I live in Blacktown so any help would be appreciated. Cheers! Greg |
Cougar
Could still be the IRMC getting stuck in the open position giving too
much fuel low down and fine when in the 3000+ range, they are know to get stuck/fail in either position, a dyno shop should be able to confirm this. Cheers Mark
2006 AFD best Cougar, 2007 AFD best in Club & best presented |
Cat Lover
Thanks Mark,
I have checked out the IMRC. Opened it to ensure the system was opening and also watched the cable connection points to see the runners opening. My gut feeling is that one of my plugs or leads are bad. When I bought the car it had a hesitation over 3400 rpm's (fuel pump problem). I changed the fuel pump and leads/plugs on the same day and my problem went from being a hesitation over 3400rpm, to one below...talk about a bummer... I think I will just have to take it to Ford so they can put it on diagnostics for me. I just hate paying money for something I think will be really simple to fix... |
Possible crank position sensor fault.. similiar occured on a 2000 cougar not that long back.. # was 1S7E-6C315BA from Ford or go to a repco and see if there is an interchange available.. can't be that difficult for them.
Regards the other posting.... whatever you did maybe you ****ed them off.. or something - but I've had no issues and as I said at least somebody is trying to help us. On the miss also.. is it only when hot /cold / or always...?? Dynatune apparently has the diagnostics equipment if there is one near you talk to them too. |
#5 | |||
Cat Lover
Hey Thunderbird,
Thanks for the idea on the TPS. I might hit a Dynatune and get the to diagnose it for me. Also in the other post, I hear what your saying, it is nice for someone to actually know and care about the Cougars in Oz. Cheers! Greg Quote:
