V8 wannaabeee
I have been to the docs about 2 months ago, and plan on going again this week. I have been getting pain (uncomfortable pain, when leaving my leg in a bent position for too long, ie; driving a car, sitting at the computer(ahuh!)
I was sitting on my forklift at my old job, and got the biggest cramp in my leg in my life! and i was stuck with a cramp and couldn't get out of the forklift for sometime, This has been an issue for 4 or so months, and its never really got to me because i was taking anti-inflammatry, and putting on some deep heat, but only seem's like temporary relief and comes back again. for 4 months on going, would this seem unusual, the last few days has got worse, and as im driving a bit i cannot keep my leg in the same position for too long, and there's not many positions you can put your leg in, in a car! lifes a struggle, as i can't do any excersize, going up and down stairs is a problem, and generally anything else that require pressure on my knee. my girlfriend thinks its a joke, or its not as worse as i'm making it out to be, but its only getting worse. anyone had this injury(similar symptoms), any advice? |
Falcon RTV - FG G6ET
![]() Join Date: Mar 2007
You should consult a Doctor - however try arthritis, as a possibility.
You could try Glucosamine (shark cartilage). If it works it'll take a bout 6 weeks to have any effect. It's a sugar so don't worry about side effects. Basically how it works is id the glucosamine is absorbed by the gut and during this process it is converted to the protein necessary for the production of cartilage. As I said, consult a Doctor.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
moderator ford coupe club
why do you have this pain. is there something that has caused it. if not, maybe check with a physio. you may need orthotics (inner sole type things that go in your shoes) to align your legs properly
this might be a really dumb question, but have you exercised it, with some unweighted leg extentions. bending and straightening the knee might help years ago, while roller skating, i tapped mine on the wall. some leg extentions do help and also orthotics do as well. before the orthotics i would have some trouble walking up and down stairs. bear in mind that when sitting your hips, knees and ankles may not be aligned and that can cause some problems. alignment is particarly important when standing and weight is on those joints. from my own experience, it is something that you do not notice until the pain starts. it is not really gradual. it doesn't hurt one day and suddenly the next it does |
Try osteopaths physio and alternative healers before surgery
Wheel Wally
If the doc's still not 100% it'd try a physio because they theoretically specialize in movement etc.
May just be a simple exercise plan to get things moving and flowing........ |
I have a very similar issue with both knees, having recently seen the doc he recommended surgery on both knees. My diagnosis is arthritis but that simply means joint pains. I was told it cant be stopped but it can be slowed down, so try and strengthen up the muscles around your knees.
See the doc and also get a second opinion, in my case im seeing another doctor soon to see if there is another way, surgery for me isnt an issue as ive been down that path before. The extended recovery period off my feet is however so i'd rather go down another path if i can. Good luck with it i wish you well. |
