Performance moderator
![]() Join Date: Feb 2005
![]() ; ![]() ; ![]() Spoke to the head engineer of this project.. When I said Australia is VERY interested in this engine... Said we have a good one already .. With a wry look on his face he said yes it took some beating.. But didn't go into it any further.. I asked where the limiting power or rpm was in this block while doing durability tests... He said the valve gear.. Seat secession etc.. The injector is beside the spark plug...
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 Last edited by ebxr8240; 12-11-2009 at 03:21 PM. |
Oooo00o...
Was there any pics of a detail sheet or anything? Did you mean he said yes to Australia getting this engine? Or something else?
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
#3 | |||
Thanks for the shots EBXR8240!
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
There is the normal specs that dealers have.. The exh manifolds leave alot to be custom made in future.. The are basically pressed steel with no pulse tuning..
Keep in mind there is very little room.. The bottom end looks the goods.. They are going to test a Mustang powered engine against am Audi 8 up Pine peaks!!! If my memory serves me correctly ?? They have already done some comparisons beating the R8 and other cars...
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 |
#5 | |||
Cobblers!
Even when Falcon was slated to receive the 3.7, we were never under consideration for the Ecoboost engine. The American engineers are very jealous of what the Australian guys have achieved with the I6, especially considering the budget Ford Australia has compared to the Yanks.
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
#6 | |||
But I can tell by the wry look on his face.. These engines will pull alot harder up top .. To take nothing away from our 4.0 camer... BTW as per VW etc the turbo's are VERY small...
That would make a Mondeo fly !!!!!!
CSGhia |
#8 | |||
Getting it done.....
I think its important to look at this as a group effort. Certainly some healthy rivalry is great but alot of the lessons Ford Aus learned on its Turbo program no doubt made their way over to the US during the design of the ecoboost range. We also know that early DIVCT studies by Ford Powetrain were used to help Ford Aus put one of the first DIVCT setups in the ford world onto the BF I6. The 'step above' position of the I6 (both NA and Turbo) is quite clearly understood by the Ford engineers in the US...and probably finally their corporate division too. There is nothing wrong with the ecoboost 3.5 (or duratec range in general)....unlike GM with the aloytec Ford got the engine right first time. It will only improve with further development. But it clearly is a lower output engine compared to the 4.0 (which is fair enough....it is smaller) and more suited to FWD/AWD applications. With Ford Aus taking the Ecoboost 2.0 I4 it could result in a bit of mutual backscratching.....they have big heavy vehicles that need the extra bit of torque too....
Dynamic White 1995 EF XR6 Auto Now with: Pacemaker 4499s Lukey Catback Exhaust Chrome BA XR-style tip Airdam Mounted CAI with modified (bellmouth) airbox Trip Computer install KYB shocks Bridgestone Adrenalin tyres Coming Soon: Exhaust Overhaul..... |
Ummm ??? Not too many big Fords.. Except SUV's ... Mondeo size is popular or SUV.. NO big cars...
#10 | |||
Two things I immediately dislike on seeing those pictures: It has Variable cam timing but it isn't independent- I and E go at the same time. Other one is the water pump being inside the timing case = a b@stard to fix if it ever goes wrong.
...sorry, WHEN it goes wrong. |
#12 | |||
Oo\===/oO
#13 | ||
i`m still a fan of the straight 6, i would`nt be in hurry to lose a good power unit we already have.
#14 | |||
#15 | ||
Dumb question from something who knows nothiong about engines.. How much benefit do they get from "Twin" turbo-ing an engine? Is is twice as good as a signle turbo? I'd love to see the I6 with twin turbo!!
#16 | |||
There are a couple of reasons for choosing twin turbo set ups and one of those is packaging on V-shaped engines - there is a lot less plumbing running two smaller turbos (one for each bank) than a single one. Additionally smaller turbos tend to spool faster and thus produce less lag. In other implementations of TT systems there is one small and one larger turbo that allows for a strong low RPM response whilst still providing solid boost at higher RPM. The current I6 wouldn't gain much from a TT set up - the torque it produces from exceptionally low RPM indicates that they have pretty much got the mix of turbo size, compression ratio and boost spot on for the nature of the engine. Cheers Russ
#17 | |||
Trev
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
#18 | |||
Peter Car
#19 | |||
#20 | ||
...but looking at those pics I'd say nothing to do with bonnet line- phasers are in the highest possible position...
#21 | ||
Don't like the single chain;)
#22 | ||
I'd take 1 chain over 1 belt any day...
