right now my under bonnet temps are pretty disgraceful and im looking at ways of reducing it once the car gets back on the road
i have pacemaker 4480s for anyone wondering, which obviously dont fit under the factory heatshield i had a chat with shav about his heatshield that he had made up and it looks very impressive has anyone else done anything similar and ran into any problems? im just weighing up the pros and cons would i be better off getting the headers heatproof coated? is it of benefit to get HPC and the heatshield as well? should i look at things like different thermostats etc? thanks for any input guys! ![]()
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
Just slidin'
Put a cover over them, or any shields, and you will void your warranty.
MD Mondeo - For the family
NP Pajero - For the adventure |
Critical Thinker
Hey Cory,
if you're not worried about the warranty, another option i have seen is heat wrap on the headers as well as the heat shield. You could also consider stick on heat mat fitted to the underside of the shield too, but that wont stop heat itself, but it will reduce radiant heat to ancillary items like brake booster, master cylinder and the accelerator cable. Better option though is ceramic coating. What I have on my car has reduced some of the radiant but in my opinion has only stopped the accelerator cable and master cylinder from melting to bits. The hot air and heat from the rocker cover still heats the intake pipe heaps. Something I plan to rectify later on.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
Just slidin'
What effect would heat wrap have on the cat? Would the temperature of the escaping gas be amplified, and cause damage to the cat?
#5 | |||
coating would damage cats due to the same reason if that was the case...?? |
Just slidin'
True, didnt think about it so logically, hehehe.
I was always led to believe that the hotter you get the cat' converter, the better they operate.
FPV GS Ute #370/Brembo brakes |
my brother tells me you can buy the heat shield stuff from repco, sorry i don`t remember the dimensions but it was quite big for about $135.00.
Critical Thinker
yes I think that comes in a sheet that you bend to your liking. Personally its ugly. But it does the job ok.
XA GT
I installed the factory heat shield on my HM headers on the XR6, havent had any problems, been on there for 6 years.
--------------------------------------------------- XA GT, 6.848sec 1/8 mile @ 101.68mph |
Critical Thinker
if its alum/alloy shield then heat will be far less than stainless. Just that stainless looks better
#12 | ||
pacemaker warranty is 24 months am i right? what is HPC worth? i guess theres probably an hour and a half's labour in taking off the headers and putting them back on and between the two i suppose they would have to be sent off somewhere, a normal exhaust place wouldnt do that sort of thing would they?
and just out of curiosity, how does a heatshield void warranty, as in does it damage the extractors somehow?
#13 | ||
To get mine Ceramic coated in Brisbane cost $275 from memory,
The set on the current car I got done by Pacemaker from new which added 220 NZ to the price, now if I hadn't had towait 7 weeks for them to arrive I wouldn't have excepted them. The coating is crap compared to the last set. I think HPC is one of those things, better spending the extra dollars as the result will prob be a lot nicer. |
#14 | ||
Just slidin'
Was there much of a difference in engine bay temps after HPC, 99Ghia?
#15 | |||
it looks crap or doesnt reduce the heat much? i guess i did the right thing not getting pacemaker HPC extractors then lol
#16 | ||||
But compared to the standard manifold and heat shield I would say it was a significant reduction going by the feel of the bonnet temp. Quote:
but just no where near as thick or as cleaner finish as the ones I had done else where. |
#17 | ||
thanks for the replies everybody, looks like ill be getting HPC done in the near future
#18 | ||
Lost Boost Gained Class
yeah i got my 4499's fitted yesterday iv got to put the Standed heat sheld back on the guy at the exhust joint would not do it
2006 BF Fairmont Ghia
2001 AU Falcon |
#19 | ||
Critical Thinker
the exhaust place obviously doesnt want to risk anything by the sounds of things.
#20 | |||
quarter pane
#21 | |||
