Old 12-01-2010, 01:06 PM   #1
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
Default Updated details on Ecoboost 2.0
After the 'End of the Falcon is nigh' tripe for this morning, here is useful info hidden in the wings. But since it's not negative, we don't see it rolled out everywhere (it's hard not to be cynical isn't it)
Key points for me - the 4cyl will use up to 20% less fuel than the current I6 so around 8.0L/100km. Will have 170-185kW of power, and will generate 325Nm of Torque from as low as 1700rpm. Nothing really new.
And if Jez was clever, he'd have mentioned that the Holden 3.0L SIDI has a bit more power (190kW), but has less torque - 290Nm at 2600rpm - and uses more fuel both in the ADR cycle and the real world.
I was OK with the rest of the article, but it's interesting that the very first thing that Jez Spinks focuses on in the article is negative. But I'm not really expecting balanced reporting any more from this guy, he's the new Josh Dowling to me ....
http://news.drive.com.au/drive/motor...0111-m1rc.html
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 01:13 PM   #2
XWGT
Powered by Marshall
XWGT's Avatar
Wow, this Jez guy is a real winner. Where did they get him from?
Powered by Marshall
XWGT is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 01:23 PM   #3
flappist
I suspect that the new T4 will be a huge winner.
A flat torque curve is what makes the XR6T far more versitile and quicker than its larger capacity, higher powered and greater max torque demonstrating naturally aspirated brother.
And really all it has to do is kick Toyota Aurion and SIDI in the nuts to grab a good share of the fleet/ordinary large car markets.
flappist is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 06:01 PM   #4
FrogInASock
Getahaircutandgetarealjob
I, however, wonder what the insurance companies will think of this turbocharged engine?
Te pilos recidene volo et opus solidus capere :
FrogInASock is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 06:21 PM   #5
Airmon
King of the Fairy's.
Airmon's Avatar
Ford says the four-cylinder engine will be roughly 20 per cent more fuel efficient than a regular V6
What kind of economy figures are the V6s in the US getting? Will be interested to see the weighbridge ticket of the 4cyl Falcon.
www.bseries.com.au/airmon
They say less talk more action,
I say more torque less traction!
Airmon is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 07:47 PM   #6
flappist
Probably the same as they used to think about the 253 V8 vs 250 I6, same risk, same cost.
Old 12-01-2010, 08:51 PM   #7
Rodp
Regular Schmuck
Rodp's Avatar
I guess it's depending on age (therefore apparently experience...) but traditionally scary vehicles like a new STI or EVO X costs the same for me to insure as a bog standard new XT (which is insured for half that of the STI or EVO) according to a few online comprehensive quotes I've done recently.
I don't think it's a case where a snail doubles the premium straight off the bat like it once did many years ago.
Rodp is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 09:06 PM   #8
Gobes32
Gobes32's Avatar
Originally Posted by Jez Spinks
The Ford Falcon's new four-cylinder engine will be down on power and torque compared with the current six.
Probably has something to do with with the motor having 2 less cylinders and half the capacity????
Originally Posted by jpd80
A G8E would be good if Ford marketed squarely at Calais V8 owners. They need to bring back the walking fingers like in the initial FG ads, but this time have the fingers crushing Calais' as they walk along, with some relaxing background Led Zeppelin music and Marcos Ambrose in stubbies and singlet driving it.
Gobes32 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 10:28 PM   #9
phillyc
phillyc's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always factual and beneficial.
Ford is still revealing few details of the 2.0-litre 'Ecoboost' engine that was confirmed for the locally built large car last July, though a torque graph was released as a teaser prior to this week's Detroit motor show.
The graph suggests the Falcon's four-cylinder turbo will produce peak torque of about 325Nm as low as 1700rpm, with approximately 320Nm then delivered along a usefully flat torque curve from about 1800-5500rpm.
A still healthy 270Nm would still be generated at 6000rpm, according to Ford's engineering graph.
A power graph wasn't included but the four-cylinder is believed to produce between 230 and 250 horsepower - 170-185kW
Use the power & torque formula... We have all the information required.
Nm * RPM / 9549 = kW
320 * 5500 / 9549 = 184kW
270 * 6000 / 9549 = 170kW
So that target zone seems right.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s
226.8rwkW@178kmh/537Nm@140kmh 1/9/2013
14.2@163kmh 23/10/2013
Boss349 built. Not yet run. Waiting on a shell.
Retrotech thread
http://www.fordforums.com.au/showthr...1363569&page=6
phillyc is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 11:36 PM   #10
Swordsman88
Getting it done.....
Swordsman88's Avatar
Yes seems about right. I feel they will rate it at 170kw but it may very well make over 180kw on 95RON. Need to leave some room to the I6 for marketing purposes of course....
As for this new data, is this atcually the Ford Aus version of the engine?? We had the numbers for the S max at 300nm. Is ths version for the explorer? Ford did quote as much as 380nm from ths engine, and while we won't and don't need that much torque i am just trying to work out the final torque figure for the aus application. Even if we use this version out of the box, 325nm at 1700rpm is alot more punchy then the competitors product....
Dynamic White 1995 EF XR6 Auto
Now with:
Pacemaker 4499s
Lukey Catback Exhaust
Chrome BA XR-style tip
Airdam Mounted CAI with modified (bellmouth) airbox
Trip Computer install
KYB shocks
Bridgestone Adrenalin tyres
Coming Soon:
Exhaust Overhaul.....
Swordsman88 is offline   Reply With Quote Multi-Quote with this Post
