Old 28-03-2010, 05:38 PM   #1
ah-see
Default Immobiliser won't disarm
Hey guys, i've run into a problem with my LS zetec.
Sometimes i can't turn the car key to the engine starting position and I assume that this is a problem with my immobiliser.
It started about a month ago and has been occuring intermittently and only recently has the problem gotten really bad. It took me about 10 minutes to get my car started last night. I lock and unlock the doors and try to start the car and i keep repeating the process until it starts.
I really don't have a clue as to what the problem is, but i'm hoping some of you guys can point me in the right direction.
Thanks
ah-see is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2010, 05:50 PM   #2
pertuan
Focus on my Focus
Might sound like a stupid question but are you sure the steering lock isn't engaged? That stops you from turning the key.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2010, 05:56 PM   #3
ah-see
Steering lock isn't engaged, forgot to mention that.
Old 29-03-2010, 08:55 AM   #4
marg99
While this may not be your problem I had starting problems because the key got a very small bur on it and would not turn the barrel of the ignition lock. Local ford dealer gave it a quick rub with very light sandpaper and has been Ok since then.
I have no idea how it gor burred and could not see the bur myself.
Old 29-03-2010, 10:24 AM   #5
ah-see
When you say that your key would not turn the barrel of the ignition lock, do you mean that the key would not turn to the first 2 positions on the ignition?
There are 3 positions on the ignition from my understanding.
My car turns to the first 2 positions, but is won't turn to the last position (engine starting position).
What's weirder is that it works sometimes and other times it doesn't work!
I'm going to try get some quotes on a new key from ford dealers. Hopefully a new key will fix the problem
Old 30-03-2010, 10:51 AM   #6
BlackLS
yum
Does the spare key work?
2005 LS Focus LX
250,000kms.
Old 30-03-2010, 10:59 AM   #7
ah-see
The key old key started working fine again.
I'm soo confused as to why this was happening, but i'm just glad it fixed itself without having to pay any money to get it fixed.
Old 01-04-2010, 06:37 PM   #8
ah-see
I brought it in to a shop and they replaced the ignition switch and now it's working again. So the problem wasn't the immobiliser and was a faulty ignition switch.
Cost me $229. $79 for a new ignition switch and $150 for labour.
Old 01-04-2010, 08:06 PM   #9
casabonka
You can call me Chris
casabonka's Avatar
Gotta love when labour is nearly twice the price of the part!
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2010, 01:29 PM   #10
pertuan
Focus on my Focus
If you think that's bad, try the clutch pedal return spring.
Spring - $9
Labour - $210
No joke. I rang up for a quote.
Old 07-04-2010, 09:45 PM   #11
20focus05
I wanna XR5
20focus05's Avatar
peruatan I would beleive that as I have done the spring myself, there is very little room to move even after taking bottom of dash away.
2 hrs it took me and skin off.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
