Old 31-03-2010, 09:03 PM   #1
4dlvr
4dlvr
Default lr focus stereo
does anyone know the key needed to take out a stereo on a lr focus..
cheers
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2010, 11:01 PM   #2
Talldude
Talldude's Avatar
These do the trick
http://cgi.ebay.com.au/FORD-RADIO-CD...item5632850e78
LR Zetec 3-Door black
With ST170 Suspension all round, ST170 Snorkel, K&N air filter, 2.0 Auto Air deflector, MSD Ignition coils and high amp leads. (In red adds at least 5bhp!) Also Under pulley kit. Refreshed ST170 wheels now!
Talldude is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2010, 01:40 AM   #3
alky89
just cut up a coat hanger and bend it into a U shape so the ends fit into the 2 holes on the side on the radio. now make another one for the other side and stick the U's into the holes. mine took a firm push to click in. then spread the U's apart and you should be able to slide the whole stereo out. if you cant get it to work or simply cant be bothered just take it to an audio store. im sure they'll pull it out for you free of charge.
alky89 is offline   Reply With Quote Multi-Quote with this Post
