Old 19-04-2010, 09:15 PM   #1
smoo
smoo's Avatar
Default testing oxygen sensors
Is there a resistance value that the O2 sensor should give? Cheers.
smoo is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2010, 11:14 PM   #2
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
I've read that resistance measurement can actually ruin it. Cos it sends a small current into the O2 sensor to measure resistance. You can measure the voltage output when hot and engine running as basic check. But I think its the response/sensitivity that's importnat, cos although it may be giving a correct reading, it may be slow to respond to change.
AMB is offline   Reply With Quote Multi-Quote with this Post
