#541 | ||
Hey guys
My passanger window wont go up, it went down now it wont work? thought it may be the switch as this is a problem but i cant put it up with the driver controls either? Any ideas? Cheers Ben |
#542 | ||
lohnro
If neither switch will move the window it is probably the motor. I have replaced mine. You have to buy the whole assembly from a second hand parts place. Not expensive considering what it does. It is tricky to remove and install but not hard. Good idea to lubricate the runners with silicon spray to ease the tension on the motor. Good luck
#543 | ||
My park brake light is fading on and off while idling. I know the handbrake needs adjusting and probably due for a new set of pads, could this be the problem.
#544 | ||
lohnro
I reckon the switch under the foot pedal needs changing. There is nothing else in the circuit that will make it intermittent.
#545 | |||
FORD FREAK
JUST LOVE THAT V8 SOUND, RUMBLE, MUSIC! |
#546 | |||
#547 | |||
66 Mustang
#548 | ||
Drivers door lock on AU3. Sometimes it will lock with the key, others it refuses to lock. Up down, back and forwards, sometimes it works sometimes it won't. Are the door lock actuators a common problem. Fix? Cost?
The remote isn't working either. |
#549 | ||
Common ... If buying new ... you need to get a B-series actuator ... with an AU jump-loom separate.
can get them from wreckers for cheaper ... but it could fail the next day ... or last for years. New price from Ford about $130-ish Used price ... not sure. Ask FTG Autosalvage (site sponsor) ... the guys will be able to help you out.
#550 | ||
Hi there,
I was wondering if it is normal that I can just pull the automatic gear lever from "neutral" into "drive" and from "drive" into "3" without pressing the button. I have to use the release button to put the lever from "neutral" into "reverse" and from "3" to "2" and from "2" to "1" which makes sense to me. And another small thing... is it normal that only the driver"s sun visor mirror has a sliding cover and the sun visor on the passenger side has just got a plain mirror without a sliding cover ? thanks for any information cheers The Moose |
#551 | |||
Extreme_Custom
If You Think AU Are Ugly ! Check my X Out......... Loved by one ... Admired by many ... Envied by most ! RIP - F6 |
#552 | ||
Our Series 3 diff got noisy just before 60K and got worse .Ford didn't want to know about it as it was out of warranty and we haven't fixed it as yet. 117K now.
#553 | |||
AU XLS. |
#554 | |||
I was just wondering about the gear lever.... Thanks for replying passengers have to sit down, buckle up and shut up lol.....or walk |
#555 | |||
Extreme_Custom
#556 | |||
my diff has been leaking for about 6 years on my AU 3 ute and i havent even checked it once ![]() |
#557 | ||
Hey Guy's, just wandering if anyone knows or has an idea about this. Driving my AU111 XR8 the other day and it was down to 65kms left till empty so I stopped at the first servo I saw and filled it up and it runs on 98octane. Hoped in it and drove about half a km and it stopped dead in the middle of the road and wouldn't start for about 5 mins. After 5mins it started and hasn't missed a beat yet. Any ideas what could be wrong?... Trying to put the wife at ease before she drives it again. Cheers
#558 | |||
Ford Fan
#559 | |||
Ford Fan
#560 | |||
Ford Fan
#561 | |||
5.0 means business
Windsor V8 Enthusiast! Turbo Barra Lover! ![]() |
#562 | |||
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
#563 | ||
Au2 xr8 2001 model was missing at idle, not so noticable under revs. Had efi dude out to repair problem, said it was computer and afs sensor so soughted new afs and sent comp away for repair, unable to fault old computer, sent back, fitted parts same thing,, then said was O2 sensors, replaced them, same dilemma. didnt call him back. Sent car to new mechanic. explained problem, missing and a vacuum leak i cannot find.
After test they said i had a coil issue, said i replaced coils twice in 2 months wasted another 1000 dollars on there recommendation, and the idiot proceeded to tell me, that I dont have a CAMSHAFT SYNCHRONIZER (or sensor) because i have pushrods. I wont tell you what i thought and said. took home noticed harmonic balancer had slipped, replaced, still same issue.Camshaft synronizer is about to be replaced. Replaced parts list for a miss 3 sets coil packs 2 sets leads 2 sets plugs 1 computer 1 air flow sensor 2 O2 sensors 1 Harmonic Balancer full set intake gaskets, valley, planem, throttle body etc plus labour at 104.00 p/h ( the joys of a mining town price but not working at a mine) and annoying the wife by having to use her (corolla). been 8 weeks now and looks like it will be ongoing until i can find someone who is capable of diagnosing. will let you know when its running as it should |
#564 | ||
VEHICLE - AU sedan 98 model XR6
PROBLEM - brown Frothy Sludge In Radiator Overflow DIAGNOSIS - Cracked Transmission Cooler Pipe Allowing Transmission Oil To Leak Into Radiator. SOLUTION - Transmission Cooler Pipe Replacement Kit Or New Radiator (chose New Radiator) COST - $350 For Radiator And $32 For Top Up Transmission Fluid RESULT- Drives Beautifully And Cool...... Last edited by Skeg37; 09-09-2011 at 07:56 PM. Reason: Forgot vehicle model |
#565 | ||
AU111 SR. Coolant leak around the thermostat housing. Fixed twice under warranty.
Noisy diff just prior to 60K and still there. Ford refused to fix it. Rust in lower boot lid ( possible leak of water from factory spoiler.) Drivers door locking mechanism failing. Power windows have had their moments but still work. Drives good, auto and engine are fine. Not buying a new Ford again as Ford Warranty Policy is questionable.
"If your wife needs a good Falcon, send her down and we'll dicker" - Early 60's Ford salesman. |
#566 | |||
#567 | |||
Ford Aus wrote to me later as a valued customer to see if I would be interested in the FG series they were releasing. You have to be joking was the answer.
#568 | ||
I have an Au XR6 1998 Adaptive shift auto. Once my car gets warm it stalls as soon as I put it in gear. I have been told it is a solenoid in the auto transmission and will cost around $450. Does this sound right? Is there any other solutions/suggestions?
#569 | ||
Finally found the problem 2 months later, poor falcon been parked up for months, one broken valve spring, they are all being replaced at we speak
and should have me car back this weekend. |
#570 | |||
AU XLS. |
