Old 12-06-2011, 01:07 PM   #1
b-juggles
Default Knock in front left after moderate to hard braking
Hi, I have an au2 that has a knock in the front left.
The pre condition for it is moderate to hard braking. Then when you accelerate it knocks again.
If you brake lightly, it won't knock. You can also accelerate as hard as you like and it won't knock after light braking.
I noticed it also does it when hitting big bumps like a pothole.
I went to my usual mechanic, who put it up on the hoist and said visually everything looked fine.
Car has done 100,000 kms
Thought on what I should try first?
b-juggles is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2011, 03:37 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: Knock in front left after moderate to hard braking
I would try a new mechanic
He should have taken it on a hot lap test drive
Old 12-06-2011, 07:58 PM   #3
b-juggles
He did...but ofcourse murphy's law played true.
Old 16-06-2011, 11:59 PM   #4
zorba289
zorba289's Avatar
i had a similiar issue and it turned out to be upper control arm bush
zorba289 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2011, 12:08 AM   #5
blueoval
Critical Thinker
blueoval's Avatar
Another vote for control arm either upper or lower.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 20-06-2011, 02:24 PM   #6
b-juggles
You are never going to believe what it was....
there was play in the door hinges so when the nose dived under braking it prompt the knock. Stuck a rag in the door jam and problem solved.
I picked up a new set of hinges on the weekend so will fit them shortly.
Just FYI - I went to Pedders and they told me there were a dozen things wrong with the suspension and wanted $2700 to fix it.
They even suggested upper control arms, which were replaced three years ago and bushes are virgin - I took them out just to prove it to myself.
There is a lesson to be learnt here....think outside the box!
Old 20-06-2011, 02:50 PM   #7
blueoval
Critical Thinker
blueoval's Avatar
Good to see the problem was found and solved. Nothing worse than a knock or squeak you dont know where to start looking at.
As for Pedders, I go to them for an inspection ONLY. Usually you only do the stuff that needs critical attention. But that is just me. Always get a second opinion. It doesnt hurt.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 20-06-2011, 04:10 PM   #8
TheSly1
Pedders have been doing this for years (and getting away with it), when is someone going to be able to stop them from this false reports that they do..
i always hear ppl getting reports from pedders for stupid amounts of money, and most ppl on forums like this, know better than to believe everything they here, but what about the average joe that has no idea and takes his family car there because he has seen there ad on tv??
what a crock
p.s glad to hear you fixed your issue... what a weird one
TheSly1 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2011, 06:58 PM   #9
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
what a crock
Strangely enough,whenever anyone has a front end related problem, the first thing members do is recommend Pedders, yet it's well documented on here how that company rips people blind.
As for going to them for an inspection? Why waste $14 or $28 dollars, when you know that you're going to get a report as long as your arm. I know where the inspection money would be better off.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
svo supporter is offline   Reply With Quote Multi-Quote with this Post
