not here much anymore
Saw it at the servo today, wondering if anybody has used it and what it is exactly designed to do?
RAM 1500
it is for modern diesel engines to reduce emissions. it is urea and is added to the cat ( I think that's how it works) all the buses we have received in the last few years all use adblue
[SIGPIC][/SIGPIC]
Lucifer's Angel
It's an additive for diesel vehicles to cut down exhaust emissions.
It's not added to fuel, but in a separate tank, injected into the hot exhaust gases, and run through a catalytic converter, turning the end product into Nitrogen and water.
![]() ![]() Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford... It's being beaten by a girl driving a Ford ![]() |
For diesel engines with SCR systems (selective catalyst reduction), the next fail thing after DPFs to reduce diesel reliability, I mean emissions.
Bandaid solution to the problem. All Euro 6 emissions diesels will most likely have it, the current Mercedes Sprinters do. |
You can call me Chris
The Diesel Mazda CX-7's need it also
'06 LS Focus Hatch -2 1/4" Lukey Exhaust -RDA Slotted discs/Greenstuff pads -Rear Whiteline swaybay -Lenso 18's w/Kumho rubber -Tinted Windows |
#6 | |||
[SIGPIC][/SIGPIC]
#7 | |||
+1 Adblue is typically a liquid urea (32.5%) solution colored blue. An Environmentally friendly chemical treatment
G6ET 50th, Havana, new Jul2011, deceased 29/4/2012 10pm Current rides: MB ML300CDI, Swift Sport BMW 535i E39 (sold) Next changeout: AMG A45, due October http://www.youtube.com/watch?v=gPzCbTNpPWg http://www.youtube.com/watch?v=k03B1ng2iEs |
Ahhh there ya go. Thanks guys.
RAM 1500
Former BTIKD
![]() Join Date: Mar 2005
It started back with Volvo Euro 4
#10 | |||
Best diesel to buy is one without all this emission B.S. i.e. a diesel Territory. Get in while you can before the rocket scientist boffins have to add even more failing technology to keep the greenies and climate change idiots happy. |
Oh dear!
Wherenoshockjocksfly Facts or the twitterverse, your choice! M3SR+ .......MG ZS EV |
#12 | ||
Add Blue?
Maybe its for Holden owners who wish they'd bought a Ford? PS: Guess what some cheapskates use instead of the commercial stuff? Its free, loaded with urea, but aint blue.
Time to Make the Hippies Cry Again |
#13 | ||
Band aid technology , Caterpillar designed the Acert engine that has multiple micro injections under extremely high pressure ( 23,200 P.S.I. ) that only injects the fuel in an ultra ultra ultra fine atomised mist as the flame path expands in the combustion chamber so it efficiently burns it without the need for these bodgy aftertreatment measures .
Chevy badges , the Polariser of the new millenia . Last edited by wrongwaynorris; 14-06-2013 at 07:07 AM. |
#14 | |||
VFII SS UTE
typically low compression diesels require it, and before someone asks. low comp diesel are identified by the use of glow plugs. hi comp diesels don't have them.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
#15 | |||
Former BTIKD
#16 | ||
I though this too but wanted to check at work tomorrow before I posted
[SIGPIC][/SIGPIC]
#17 | |||
VFII SS UTE
euro 5 a DPF is only needed with higher comp, but a low comp requires both.. euro 6 all makes/models require DPF and eurea. ------------------------------------------------ low comp glow plug needed in europe 14:1 ~ 18:1 (16:1 or higher not needed in warmer climates) hi comp no glow plugs 22:1 ~ 26:1
#18 | |||
Former BTIKD
Euro 6 hasn't arrived in Oz yet.
#19 | ||
we have quite a few Volvo B7 Euro5 and I think a few are Euro4 all have ad blue. Why is it called Ad blue seeing it is clear not blue?
[SIGPIC][/SIGPIC]
#20 | ||
It is not directly related to compression, or glow plugs, etc.
Your typical Catalytic convertor for a petrol engine is a “3-way” convertor. Nitrous oxides are reduced to Nitrogen & Oxygen and the oxygen is then used to burn off any unburnt hydrocarbons and convert CO to CO2. Diesel engines typically could not use “3-way” convertors because they run too lean to reduce the NOx (so they would only use “2-way”.) Hence why the Euro standards have been softer on NOx emissions for diesels. However the latest diesels are now fitted with newer type of “3-way” convertor. They inject a urea mixture into the exhaust where it is converted to ammonia which is then used to reduce the NOx into Nitrogen and Water. It is injected electronically, at about 2% of the diesel consumption rate. “Adblue” is a trademark, maybe it makes the exhaust blue? But it is basically high purity Urea and water.
#21 | ||
VFII SS UTE
but Volvo is a European truck that conforms to euro standards, forget Oz standards.
#22 | |||
VFII SS UTE
urea is for both particulates and NOx hi comp engines give less particulates. hence DPF only for euro 4/5.
#23 | |||
VW has something as well with the word "blue" in it, referring to SCR systems. |
#24 | ||
Sure do, Opel use urea injection.
Sure has, Mazda are Euro6.
Fords the family have owned: Model T, Model A, Fordson truck, 105E Anglias, MkI Escorts, MkI Cortinas, MkII Cortina, Zephyr Six, ZC Fairlane, AUII Ute manual, BA XT sedan, Territory TS SZ RWD. |
#25 | ||
Peter Car
