Old 03-07-2013, 08:59 PM   #1
Fergo
Default Throttle body
Hi was wondering if anyone new if you can put a turbo throttle body on a na if so can I put the hole intake manifold. Are stock injectors same?
Fergo is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2013, 09:25 PM   #2
40RDT
40RDT's Avatar
Default Re: Throttle body
Im pretty sure the n/a 6 and turbo 6 throttle bodies are the same
FG XR6T Ute
300rwkw
40RDT is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2013, 09:53 PM   #3
Fergo
Ok cheers I also have just bought a turbo kit for my 03 xr6 na and have bought some turbo pistons rods and valves turbo head gasket would that be enough to lower compression do u no.
Old 03-07-2013, 09:54 PM   #4
Fergo
Won't to run about 10lb daily.
Old 04-07-2013, 06:08 PM   #5
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
I think you may be better off posting in the B-Series room or the BA-BF section.
More guys in there that could answer your questions. Give as much info as possible.
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
