Old 17-08-2013, 02:15 PM   #1
canuk7
Default resetting base idle
Hi guys,
sorry to bring this subject up again but I am having a problem setting my base idle. After disconnecting the iac and placing a 075mm feeler between the idle adjusting screw and the throttle stop plate, when I start the car, the car revs very very high. I don't think it should be reving that high. Am I doing something wrong in the process? Any help would be appreciated.
Thank you
canuk7 is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2013, 04:16 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: resetting base idle
Huh? Is the IAC still disconnected?
Old 18-08-2013, 02:42 PM   #3
canuk7
Thanks mr hardware and sorry I was unable to respond to you earlier.The iac remains disconnected.
Old 19-08-2013, 10:15 PM   #4
Mr Hardware
I often find that connecting my iac provides a better idle. Do you have a reason to disconnect it?
