Old 14-03-2013, 11:15 PM   #1
JFJ
Default Fiesta 07 Cigarette Lighter Always On Fix?
Hi All,
I posted this over in the electrical forum a few days ago but I thought I would try it over here as well..
I have been doing some hunting around for some time on the subject of how to easily make the cigarette lighter only turn on when the ignition is switched to accessories or beyond. I have a bluetooth device that will just drain the battery if left in there and I am not interested in just unplugging it every time I get out of the car.
So.. with a bit of help from my multimeter I have found out that one of the 2 trailer towing module power supplies at the fuse box is only active when the ignition is on. My question to you all is can I just use this power and redirect it through a fuse to the cigarette lighter? Or is this not capable of running my 12v? I just dont want to draw too much from something if its only supposed to be small draw.. fire is bad!
Cheers!
JFJ is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2013, 11:36 PM   #2
Pursya
Default Re: Fiesta 07 Cigarette Lighter Always On Fix?
Are you saying the cig lighter is permantley on?
I've never seen that before.
If this is true I need to disconnect the GPS.
Pursya is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2013, 12:58 AM   #3
JFJ
Hi Pursya,
I believe its a ford thing to have them permanently live..
Very annoying!
Old 15-03-2013, 09:41 PM   #4
Pursya
I've had Mazda's, Holden's, Suzuki's, Eunos's and have never as any accessory stay on after the key had been removed.
It certainly is a "Ford thing".
Old 16-03-2013, 01:22 PM   #5
vhcbm
having Fiesta withdrawals
vhcbm's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Ford couldn't fix my BlueTooth issue. This member posted a download link, with instruction, on how to do it myself. One week on, the unit hasn't played up once. Three different dealers told me to virtually 'Live with it.
09 one does it as well. just don't plug anything into it.
I don't think it's just a Ford thing as my work car (falcon) doesn't do it.
New: Ford Focus RS in Ultimate Green number 82/315
Past: 2009 Ford Fiesta LX in Vision Blue - Sold
vhcbm is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2013, 04:54 PM   #6
FTRXR8
FTRXR8's Avatar
My 07 WQ didnt, But my 12 WS 'Metal' does, Could it perhaps be a Ford Germany 'Thing'?
As a result of leaving a phone charger plugged it, how long would it take to flatten the battery?
2015 Fiesta ST
Custom Paint
17x7.5 Rota Titans
Tint
USA Focus ST Carbon Fibre shifter
Mountune Symposer Delete
Blue ST Badging
FTRXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2013, 02:10 PM   #7
vhcbm
vhcbm's Avatar
07 WQ was German so it can't be that.
Old 17-03-2013, 02:16 PM   #8
naddis01
naddis01's Avatar
Same deal in the new Ranger. You would think if they were going to do it like that in the Ranger they would make one of the 2 live all the time and one only with accessories.
naddis01 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2013, 05:03 PM   #9
JFJ
Originally Posted by JFJ View Post
Hi All,
Cheers!
So thinking more about this, I think it could be like the accessories relay for the towing module.. do you think that if I connect the 12v outlet to that there will be trouble? I don't imagine it will really matter that much..?
Old 24-08-2013, 09:26 AM   #10
Lewy
Lewy's Avatar
I love the fact that its always on!! I have a fridge in the back and need it to stay on at all times.. Never had the battery go flat.. Its a 50l wacol..
2011 FIESTA ZETEC DIESEL
Lewy is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2013, 04:27 PM   #11
NanoDuke
NanoDuke's Avatar
Can't you tap into the radio power supply rail?
NanoDuke is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2015, 11:18 PM   #12
96xrgr8
Just bought an 06 Fiesta and plugged a dash cam in to the cigarette lighter socket, only to discover that it is permanently on. Obviously not an issue if you unplug it after driving, but if i leave it plugged in, it also keeps the dash lcd screen on, and the stereo light on? Has anybody got a firm solution for this yet?
96xrgr8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2015, 11:23 PM   #13
Pursya
There are wiring solutions available.
Require a double fuse plug that is then plugged into a slot that switches off with ignition. The wire output is then plugged into the "cold" side of the cig lighter fuse block.
http://www.ebay.com.au/itm/2-x-Add-A...item463e212daf
I have the unit but havent got around to installing.
Old 21-07-2015, 01:59 AM   #14
96xrgr8
Much appreciated, will look into that asap.
