Old 14-08-2014, 11:00 PM   #1
GTMRK2
Default Tc cortina v8 conversion
gday guys im on the hunt for a tc Cortina to build into a v8 street car (most likely with a 351 Windsor if I can with engineering) , I live in Victoria so not to sure about the rules with engineering yet but ide like to know what to look out for when buying a tc for a v8 conversion, ive heard you want one with the recessed fire wall not the flat fire wall, does it matter to buy a 4 cylinder or a 6 cylinder what is easier ? any info would be great cheers
GTMRK2 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2014, 11:13 PM   #2
BIONIC MAN
Two turning.. two burning
BIONIC MAN's Avatar
Default Re: Tc cortina v8 conversion
I think just finding a TC Cortina worth buying these days will be your biggest challenge!?
I came "this close" to buying a TC with a Windsor back in the day.. but after a test drive Dad thought it may not be the best car for an 18yo.. so I bought a 351 xc ute instead.
and also the TC kind of had "backyard conversion" written all over it..
I LIKE BLOWERS, TURBO'S.. AND ENGINES BIG ENOUGH NOT TO NEED EITHER
BLOWN, 2013 FPV GS UTE
TURBO TERRITORY GHIA
545ci XB GS UTE
Daily, 2006 F250 crew cab
BA2 Fairmont Ghia
BIONIC MAN is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2014, 10:08 PM   #3
isaacreindl
need upgraded brakes, springs, reinforcing on the chassis just behind front wheels, reinforcing for gearbox,, then you gotta get a custom exhaust and thats gotta be tested to certain db levels, amongst other things.... its a lot harder hear in perth but my cortina has been licenced with its conversion in nsw for 17 years and now i've brought it here i have to get the exhaust redone as its apparently too loud. If you could find one already engineered and registered it would be a lot better and save some money, other wise the rod shop sells kits with the engine mounts and re inforcing brackets etc for 450$
isaacreindl is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2014, 04:23 PM   #4
GTMRK2
thanks mate wasn't aware of the reinforcing of the chassis, definitely not easy getting cars engineered, thanks for the info
