Old 08-10-2014, 09:09 PM   #1
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Default Peddal box pin capri 1972
Hi all
i have a major problem with my peddal box. The sir clip that holds the pin cames of and my clucth peddal moves. Has anyone got any better ideas for this problem....
I was thinking even putting a bolt straite threw ...your thoughts..on this
thanks
WOGBOY69 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2014, 10:28 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: Peddal box pin capri 1972
are you able to drill a hole through the pin and pop a split pin in the drilled hole
if you use a bolt make sure its a nulox nut and flat washer that will hold
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2014, 08:09 PM   #3
allanv6gt
Tippy-tronic Free Zone
Presume you mean the 1/8" thick square section circlip. Probably just stretched.
A photo would help to confirm the item.
PM me your address and email...I'll send one to you gratis.
allanv6gt is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2014, 09:16 PM   #4
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Hi dirty hands
that was my first thought . But drilling a hole while its still up there mite be very hard . I realy dont want to pull everything apart again. Booster and pedal box . Its a real pain. Such bad spots to work in.
Allanv6gt
i dont know about square section. Its at the end were the clucth pedal is round pin and it has a slot on the end of it to put a circlip .
The circlip is very new maybe the clucth pedal has play in it and wants to kick out the peddal ..ill send you a pm..
Old 09-10-2014, 09:18 PM   #5
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Hi all
just want to know can you pull the pin out while every thing still stays there . Or do you need to pull every thing out
thoughts
Old 13-10-2014, 05:43 PM   #6
allanv6gt
Wogboy, PM today, and email sent yesterday with pics for confirmation of part
