07-01-2006, 12:36 PM | #1 | ||
hey guys, as you know my Au is no longer in my care as my littel brother is driving it, since then heaps of problems have popped up, stuffed right window, wont go all the way down, broken windsheild, etc etc..
Now the Power steering has decided to give up the ghost. My little brother noticed a buzzing sound when he came home the other day when he pressed the accelerator or turned the wheel. upon inspection of the power steering fluid resivour, it was completely empty! So i filled it back up, and today checked it and its empty!!!!!! I stuck my head under the car and noticed alot of oil on the left hand side where i am guessing the steering arm is. Now i dont know nothing about all this stuff, At a guess it seems a hose has come off or bursted under pressure, I bought some new car ramps today, but cant get the damn car up because of the stupid bodykit, my jack's wont lift it up high enough to put my body under to have a good look. Has anyone had any dramas with this problem yet, or is it just me? I thought i would ask here before taking it to ultratune to get it checked out! any advice would be great! Thanks Rob |
07-01-2006, 01:45 PM | #2 | ||
My kids think I'm cool
think the t3 has done the same thing mate.....
2011 FPV GT 335 >My Build Thread< (Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page) BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable... 2018 Ford Ranger RAPTOR 2013 Audi SQ5 |
07-01-2006, 02:16 PM | #3 | ||
damn, i think i will just take it down to ultratune and pay the pricks to check it out.
cheers rob |
08-01-2006, 12:53 AM | #4 | |||
08-01-2006, 02:34 PM | #5 | ||
do you know if it is "safe" to drive it like this?
i know it cant be good, but my brother needs it to get to work this week, should i just fill it with some cheaper oil? i put some good mobil stuff in it, but its a waste of money when it comes out in an hour or so! |
08-01-2006, 05:22 PM | #6 | ||
If its leaking out within an hour, id suggest prbably not driving it, and getting it fixed as soon as is practicle. Mine is leaking empty within a 4 or 5 days, and im still pretty hesitant to drive it....
08-01-2006, 09:44 PM | #7 | ||
yeah i am getting the car checked out on monday/tuesday, hopefully only a pipe has come loose or something.
08-01-2006, 11:19 PM | #8 | ||
I think you will find he has done a seal in the steering rack, all the power steering fluid collects in the rubber boot, if he keeps driving and it has no power steering fluid he can stuff the power steering pump as well, better not to drive it.
I had the same problem this week had my power steering rack replaced. |
09-01-2006, 12:38 AM | #9 | ||
Miami Pilot
I had my PS pump reconditioned (they do it on an exchange basis). It was about half the cost of a newy - around $250, I think.
09-01-2006, 01:14 PM | #10 | ||
Next upgraded Mk1 Leopard
Mine went had it replaced under extended warrenty.
Uncle Ken
09-01-2006, 03:29 PM | #11 | ||
holy crap.. $250... stuff that, time to kick my brother up the *** and tell him to get a job!
i was hoping it was only a seal or tube, damn it. I havent booked it in yet, i am going to try and get under the car this arvo and see what i can find! cheers rob |
09-01-2006, 04:49 PM | #12 | ||
ok, just pu the car on some stands so i could get in under it....
i wiped all the oil splatter of where i thought it was coming from but that all seemed to be fine and clean with no oil leaks. started the car up and got my brother to turn the wheel left and then right, when he did this it started weeping oil from this little contraption..... It is pictured below, it is the thing with the blue plastic cap on it. anyone know what it is?? from the top from uner the car cheers rob |
09-01-2006, 06:26 PM | #13 | ||
Miami Pilot
Looks like the steering shaft to me.
09-01-2006, 07:34 PM | #14 | ||
and what would i have to do.. replace a seal or the whole thing?
09-01-2006, 07:40 PM | #15 | ||
they call me Tibbo
its only a rack switch mate
cheapie and you can get them from REpco.. You need a thin and stumpy 13mm spanner to fix it though
09-01-2006, 07:44 PM | #16 | ||
So thats what the leakage would be from yeah?
that is good news then! |
09-01-2006, 08:06 PM | #17 | |||
they call me Tibbo
09-01-2006, 08:17 PM | #18 | ||
Do what Racecraft says because you'll only screw up the rack and power steering pump and you'll be up for a rack and pump and your wallet will be lighter by at least $1000. Running them dry aint a good thing
09-01-2006, 09:03 PM | #19 | ||
wow, didnt know that the set up is worth $1000 geebus!
I am off to repco in the morning then. damn windows wont go up or down either... need to lube them up, funny how my au has decided to get jealous of me driving the BA so much LOL |
10-01-2006, 08:46 PM | #20 | ||
All done fellas, bought the rack switch from repco, $45 or something like that, cut a 14 spanner in half, got a mate who is a mechanic to change it for me in the drive way.. EASY!
thanks for your help fellas Rob |
14-01-2006, 08:00 AM | #21 | ||
Automotive Graphic artist
It must be an AU thing because mine is haveing the same problem, just started, I also have to replace the Transmition sump gasket. Everything decided to go at the same time!!
14-01-2006, 09:02 PM | #22 | ||
i had a similar problem with my AU and took it for one of those $14 steering and suspension checks at Pedders and $800 later i had a new rack and pinion, mine was leaking inside the dust covers u see in the pic previous, if u take the tie off the cover it will more than likely be full of fluid i would think. the money i spent at pedders bought me a reco rack and pinion but they added a fluid filter which isn't standard cause they believe any system that relies on the oil traveling through it needs a filter. made sense to me and haven't had a problem since.
15-01-2006, 05:11 PM | #23 | ||
i think you got ripped, BIG TIME!
it sucks, you could have found out what was needed and gone to a wreckers and paid a mechanic $100 for labour and get it all done for well under $800!!! |
15-01-2006, 05:23 PM | #24 | |||
18-01-2006, 08:08 PM | #25 | |||
03-02-2006, 05:13 PM | #26 | ||
Had my rack also replaced as it was leaking. $500.00 later the power steering goes.
There was 1 side effect which happened 2 months later which apparently is common with the AU. Leaking fluid onto the alternator. Eventually it burns out, for me it was in the middle of the city at night. 4 hours later $350 to Mr RACV for a new one. Guys if you had a power steering leak make sure you check the Alt. |
