Old 20-03-2015, 03:57 PM   #1
xr8 007
xr8 007's Avatar
Default Another rough idle issue,,kinda
Hi all,
Got a SII Fairmont. Recently put a new alternator in which charges correctly according to my volt meter, on full and no loads etc.
However when stopped at lights, it develops a light rough idle under load when I have lights on, demister and heater/air con on etc. Is hard to describe because the idle itself is fine however it causes the car to give off a light vibration.
If alternator is charging correctly, what other things can I look out for? I have cleaned the throttle body and IAC valve and also changed the spark plugs.
Fuel mileage is perfect and spot on so my oxy sensor should be ok also.
Or am I expecting to much out of a 15 year old car? Expecting it to work like a brand new FG?
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2015, 06:06 PM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: Another rough idle issue,,kinda
Hi xr8 007, i would probably check all bolt on's are bolted snug & tight under the bonnet & under the car especially the exhaust & cat. Good luck!
cheer's, Maka
Old 21-03-2015, 11:26 PM   #3
Spurious
Engine idle reset?
https://youtu.be/kN8Z5jOl2WQ?list=UU...0EW8-YuKL9a9VA
Mine runs like an FG....ONLY LOUDER!!!!!!!!!!!!!!!!
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2015, 05:35 PM   #4
xr8 007
xr8 007's Avatar
thanks dudes, will have a look.
Old 14-07-2015, 10:53 PM   #5
xr8 007
xr8 007's Avatar
So still having this issue even aftef ecu reset. Interesting that there was a slight improvement at the start but the issue is back. Any other suggestions??
Old 14-07-2015, 11:40 PM   #6
bluestripes
Q - CAR
bluestripes's Avatar
try tightening the bolts on your TPS.
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2015, 03:22 PM   #7
Maka
Maka's Avatar
Long shot xr8 007, but is the battery the right amperage? Also have a suss of your inlet manifold bolts & clean your ics valve on the throttle body. If all fails consider getting a ecu scan to see if everything is all good sensor wise. Good luck!
cheer's, Maka
Old 30-07-2015, 11:25 PM   #8
aufalco
Alternator
If its only happening under load should be power related. Coil pack, check HT leads. Could be battery failing. But it wouldn't hurt to make sure the idle control on the throttle body is definitely clean and working. Pull it out of the car and clean it out properly if you didn't already.
aufalco is offline   Reply With Quote Multi-Quote with this Post
