Old 05-01-2016, 12:42 AM   #1
falcongt4me
TSCoA member Qld
falcongt4me's Avatar
Default Wheel Lock Nut
Hi all,
Bit of a long shot I know, and I am following up on a couple of other leads, but I am after a specific wheel lock nut coded 5B38 (as pictured).
Enquiries at a Ford Parts depot lead me to believe that the lock nuts were outsourced, and the company has since gone under. However, the silver lining is that this coded lock nut was one of the more common ones used for Tickford wheels (apparently there were only about 6 differing combinations).
If you have any old lock nuts from original wheels lying around, I would greatly appreciate it if you could check the code. I am happy to pay a small fee to compensate if required and postage.
I live in the north end of the Gold Coast.
Any help would be greatly appreciated before I get a 'flat'!
[IMG][/IMG]
Cheers,
Martin Mac.
2002 AUIII TS50 Liquid Silver #206 (ex NZ)
T-Series Club of Australia member; QLD
falcongt4me is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2016, 06:50 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Cool Re: Wheel Lock Nut
I have these 2 types and the wheel nuts they fit... one is yours
Hope this helps
UK
Uncle_Ken is online now   Reply With Quote Multi-Quote with this Post
Old 09-01-2016, 02:38 PM   #3
Dingo
Ford T3 Partsologist
Dingo's Avatar
Default Re: Wheel Lock Nut
you should be able to get replacements made Thru Ford - i think they are done out of South Australia - will check it out on Monday for u
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2016, 03:15 PM   #4
Dingo
Dingo's Avatar
Ford have 1 set left in the country in WA warehouse - 1 of the 6 types of GENUINE sets of 4 lock nuts and 1 socket (different codes on socket tho) can have it with me on Tuesday
$185.00 inc GST plus post
still will check Monday to see if i can get a 5B38 replacement nut and socket
Old 10-01-2016, 04:21 PM   #5
falcongt4me
TSCoA member Qld
First thing I did was check with Ford...and they told me the SA company that made them for Ford has gone, as is no longer trading.
Cheers,
Martin Mac.
Old 10-01-2016, 04:23 PM   #6
falcongt4me
TSCoA member Qld
Thanks Dingo, really appreciate your help. If you can get a replacement 5B38 socket that would be fantastic...keep me posted
Cheers,
Martin Mac.
Old 10-01-2016, 04:40 PM   #7
falcongt4me
TSCoA member Qld
Hope this helps
UK
PM sent...
Cheers,
Martin Mac.
Old 11-01-2016, 03:05 PM   #8
Dingo
Dingo's Avatar
Howdy Martin FYI the Ford set that i can lay my hands on out of Perth, has a Socket marked 6B38 (yours is 5B38) and the lock nuts are 40mm overall length
Old 11-01-2016, 04:08 PM   #9
Dingo
Dingo's Avatar
Old 09-02-2024, 12:16 AM   #10
cslcsl
Hello all, looking for an Ford Wheel Lock Nut as close to this as I could photo;
https://drive.google.com/file/d/1Koe...usp=drive_link
https://drive.google.com/file/d/1gcC...usp=drive_link
https://drive.google.com/file/d/1v7_...usp=drive_link
It is NOT 6B38 because I have that and it does not fit.
Happy to pay for postage and tracking and than can send it back to you my cost. All I need to do is take 4 nuts off. Misplaced this damn original socket and cannot find it.
cslcsl is offline   Reply With Quote Multi-Quote with this Post
