Old 25-10-2017, 04:43 PM   #1
Dingo
Ford T3 Partsologist
Dingo's Avatar
Default Steering rack difference
Howdy
Need to replace Rack in a October 2001 XR6 with VCT - Have a rack out of AU Fairmont with VCT - But Ford saying they are not the same............
AU XR6 with VCT and AU FAIRMONT with I6 VCT have different Steering racks listed on Fords parts catalogue, i would have thort they would be the same.....
Does anybody know what the differences are please.
thanx Dingo
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2017, 05:04 PM   #2
mcfly94
mcfly94's Avatar
Default Re: Steering rack difference
I looked into it but every rack supplier assured me they're identical and differences ended when the El model ceased. (Speed sensitive and the Gt)
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2017, 04:55 PM   #3
NCII40
XR6T BA 2002
NCII40's Avatar
I was told to heat shield where the extractors and rack boots meet,
Can extend the life of the rack and boots
Any thoughts?
XR6T 2002 BA
Old 28-10-2017, 05:32 PM   #4
mcfly94
mcfly94's Avatar
Any thoughts?
Never known anyone to have issues with cooking boots or heating up the fluid (and inadvertently damaging the rack) like vt-vz v8's.
The extractor design on all au v8 headers ive seen is suffice (hurraciane, pacemaker and difilippo)
Old 30-12-2017, 07:08 PM   #5
mik
mik's Avatar
I dont know about the 8`s , but on the 6 cylinder models depending on the extractor type , they can come a bit close to the rack , mine does anyway .
the rack on the Au`s seems pretty solid , the only weak spot imo is the o ring seal at one end of the rack where they usually leak from eventually , and usually results in the whole good working rack being swapped much earlier than need be .
I think ford could have done a little better than a 50 cent o ring to the job , but it is what it is .
Old 30-12-2017, 11:30 PM   #6
Bill M
Bill M's Avatar
Interesting question. I did a quick search and found some references in the this post, https://fordforums.com.au/showthread.php?t=11206665
From member "The Mighty Red"
Lift the bonnet of your car, look down to wear your steering column meets the steering rack , looking straight back at you will be a valve attached to the rack , if there is only one valve then it is a standard rack, If it has two valves then it is a speed sensitive rack....
AUII XR6 VCT ute
20 years and still going strong!
