Needav8
On an AU3 XR8....
What do these do? I ask because my speedo works fine, but my ECU is throwing a code for the VSS......? Will the VSS effect the engine/tune etc in any way if throwing a code?
Back in the game with an '02 AUIII manual XR8 ![]() |
Maybe not - the VSS is used as an input to the PCM and ABS systems as well as providing data to the cluster via CAN bus.
So what is the fault code ??
Needav8
I use Forscan and it literally says VSS, not sure what the code number was.
Was throwing a cam posi sensor fault too which I replaced and it went away.
Needav8
Needav8
So I got under there today.
There was some oil seepage on the sensor, cleaned it all up then pulled the plug apart, wasn't easy as there was some green corrosion on the pins. Cleaned it all out and put it back together full of RP7 and the VSS fault code is gone...
2009 xr turbo,2004 fiesta
Im getting this code on my s3 xr8 too,im assuming its the speedo sender that causes this?
Might have to give mine a clean too,my speedo also works fine. |
#8 | |||
Au Falcon = Mr Reliable
cheers, Maka
FG XR50 TURBO
![]() Join Date: Apr 2009
I think I had the same issue with my AU Fairmont turned out to be a faulty ABS module
as Maka has mention what other codes are you getting ?? https://fordforums.com.au/showthread...le#post6009355 cheers Dean |
