12-02-2021, 10:18 AM | #1 | ||
Hi everyone
Eventually want to upgrade to the ax wifi from the ac and also want the mesh wifi that covers whole property. Have the following routers in mind and wondered which is best 1. ASUS rt-ax82u 2. ASUS rt-ax88u 3. ASUS rt-ax92u 4. TP-link archer ax73 with tp-link re605x extenders 5. TP-link archer ax50 with tp-link re605x extenders 6. TP-link archer ax90 with tp-link re605x extenders If using ASUS what listed model would you use at the main and extension spots for mesh. Also if you already got a wifi network at home wether it be seperate modem and router or modem/wifi router In one is it possible to plug another router into the modem/router to have a completely seperate wifi network just for you wether or not you have 2 mesh wifi systems Thanks |
12-02-2021, 10:28 AM | #2 | |||
tbh for home use I think they are all much of a muchness. How big an area are you planning to cover, how many users, and how much data transfer?
having said all that though, after running wifi and extenders for years I've just ran CAT6 though the house. You may want to look at that, or Internet over Power as another option |
12-02-2021, 10:32 AM | #3 | ||
So the cheapest or just a ax1800-ax3000 wifi would be good enough
12-02-2021, 10:41 AM | #4 | ||
Bolt Nerd
car10002, with all due respect mate... Do you actually FULLY read people’s replies? (And not just this thread!)
The question was asked... “how large an area?” This would be a determining factor, I’d think
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
12-02-2021, 11:25 AM | #5 | ||
covering about 550m2 block all up and 3 bedroom house if it helps people
12-02-2021, 01:10 PM | #6 | ||
in terms of wifi setup and networks a lot of the devil is in the detail. The 'best' router in a bad location may not deliver as good performance as something cheaper in a central, high-up location with no walls blocking the view.
if you want to go -ax make sure that all the devices you are planning to connect are backwardly compatible. Performance will be limited by the slowest device you have. ie the ability of an -n or an -ac device to receive the data packets, not the speed at which the -ax router sends them Suggest you read some network IT sites. It's not rocket science but there are definitely a list of do-s and don't-s. Or ask the question on an IT forum not a car forum if you want a definitive answer |
13-02-2021, 01:10 AM | #7 | ||
An important factor also would be: Is there much RF 'noise'. Anything including the old holden next door, the Channel 7 transmitter in the yard across the road, your other wifi tools, your neighbour's wifi.
A wifi analyser app can help with the last one. I don't mind my Orbi, but I wish it had external antennae so I could put some high gain ones on. |
17-02-2021, 12:11 AM | #8 | |||
BANNED
LOL...that is a kindergarten sized coverage area. Be careful...every wifi hop/router halves your speed. Just get an amplifier...about a 5watt unit from ebay should do it. Just make sure your access point has screw on antennas and thats all you need. Anything else is way over the top.... |
17-02-2021, 09:13 PM | #9 | ||
Get a router that supports VLANs. That will address your original question. I haven't looked at your list, but it should tell you if you look at the box / specs.
What dodgey stuff are you hiding from your missus? |
18-02-2021, 07:03 PM | #10 | |||
Hopefully follows pro advice and get it done. |
