Old 17-01-2021, 01:47 PM   #1
AussieG62013
AussieG62013's Avatar
Default Car Stands On MD Mondeo ?
Is anyone else having issues trying to use your car stands on your 2015 Mondeo I can't seem to place my stands due to the car jack being in the way.
I wan't to replace my rotors and pads myself becuase the mechanics are ripping me off to do the job.
FORD FG MKII G6 2013
FORD Mondeo Titanium MD Hatch 2015
K&N Air Filter
AussieG62013 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2021, 02:04 PM   #2
adyadad
Default Re: Car Stands On MD Mondeo ?
Have you tried placing them under the lower control arm? Perhaps not as high as you'd like but works for me.
adyadad is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2021, 02:07 PM   #3
AussieG62013
Isn't that like a big no no location
K&N Air Filter
Old 17-01-2021, 09:38 PM   #4
adyadad
I've been working on cars for more than 40 years and never had a problem. Just let the jack down carefully and make sure they're solid. I always lift the whole front using 2 jacks then place the stands.
Old 17-01-2021, 11:19 PM   #5
AussieG62013
But were can the stands go in a safe location without the jack being in the way.
K&N Air Filter
Old 18-01-2021, 05:06 AM   #6
adyadad
It's tight but can be done. I use small trolley jacks, not the one supplied with the car.
Old 18-01-2021, 08:29 AM   #7
rondeo
https://www.amazon.com/Powerbuilt-64.../dp/B003ULZGFU
AussieBlue posted that link see p.10.
see also:
https://www.fordforums.com.au/showthread.php?t=11469705
Old 18-01-2021, 03:46 PM   #8
AussieG62013
Originally Posted by rondeo View Post
Thanks mate never seen a jack + stand in one before it's an excellent idea thanks. But does someone in Australia sell these thou ???
Actually that won't fit under the mondeo's these are only for suv's or non low cars.
K&N Air Filter
Old 10-02-2021, 09:27 PM   #9
cobrin
Challenge Accepted!
cobrin's Avatar
I use a low profile jack under the subframe bolt it's hefty enough and spreads the weight over a decent area then I use stands under the pinch seam or something like that, Ford the idiots cracked the side skirt/spoiler early on and we didn't notice it till it were too late. ****ed me right off (even though it's my folks vehicle). I'll get a pic one of these days for you. I think I have a tyre rotation due soon for them.
Undecided replacement...
Old 10-02-2021, 11:08 PM   #10
Buy a small low profile trolley jack (e.g https://www.repco.com.au/en/tools-eq...35?search=jack or https://www.supercheapauto.com.au/p/...kg/563848.html if it fits) with a support like this to use with your jack stands https://www.repco.com.au/en/brands/s...19?search=jack support or https://www.ebay.com.au/itm/Rubber-S...oAAOSws3pcnxI2 and see https://www.youtube.com/watch?v=duQWuHdSyi8) for ideas.
Note that the factory workshop manual Section 100-02 (and doubtless also the owner's handbook in your glove-box) specifically states the jack that came with car is only designed for and, should only be used to change a deflated tyre in an emergency, and never to use that jack to hoist the car for any other purpose. Essentially, they are not stable enough to use for any mechanical repairs and maintenance where even a hand might be under the car and be crushed if they tip over.
Old 10-02-2021, 11:22 PM   #11
AussieG62013
I have two jacks one normal one low profile and it's what I have been using the car jacks are not the issue the issue is the car stands I am not able to place them in the only suitable location as the conflict with the car jacks.
K&N Air Filter
Old 12-05-2021, 08:44 PM   #12
AussieG62013
Just an update on this I had to remove the engine shield to see better were stands could go.
K&N Air Filter
