Old 09-08-2021, 01:14 PM   #1
Juniper
Default cougar headlights
can anyone tell me if headlights from a 2000 series 2,Cougar are compatible with my 2001 car ? currently has one original and one Eibach light.
Juniper is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2021, 07:28 PM   #2
Juniper
Default Re: cougar headlights
obviously no one knows if it would fit.
So here is an easy question, the original headlight gets water in it. where do I
get it repaired or buy a new seal ?
Old 16-08-2021, 11:34 PM   #3
GTLEGEND
So there are two different headlights on Cougar.
From 1/6/1999-31/8/2000 RH F8RZ13008HA LH F8RZ13008JA
From 1/9/2000-2001 RH 1S8Z13008DA LH 1S8Z13008DB
Hope that helps if you need to find what month and year the donor light will come from to see if its right for your car, ie it needs to be after 1/9/2000 to fit your 2001.
Old 06-10-2021, 10:28 AM   #4
WildRacer
Cougar King
WildRacer's Avatar
Post Re: cougar headlights
Hi Juniper,
Yes both of the Cougar model headlights are interchangeable. I've personally installed 2001 headlights into my 2000 Eibach, which I think look great!
See link here: Here!
00 Eibach Cougar
Mods:
Escape 3.0 V6
ST220 UIM and LIM
NPG Fuel Adapter
California Clutch Stage 2 Disk and PP
ST200 Flywheel
Torsen LSD
Updated Shift Forks
ToyoSport Exhaust Headers
Custom 2.5" Exhaust dual
BAT 21mm RSB
PRT Heavy Duty rear drop links
Energy Suspension Polybushes all around
Eibach Suspension
Eibach body kit
01 Gauges
01 Steering Wheel
Aluminium Sports Pedals
Sony Double Din HU
ST200 Airbox
ST200 TB
Direnza ST200 Aluminium Radiator
Goodridge Brake Hoses
WildRacer is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2021, 12:02 PM   #5
Juniper
Wild Racer, the Eibach headlight I had is black so doesn't match the other. Also they don't just fit so we had to take out the little plastic grill and move it out a bit, and make a temporary bracket so the bonnet would close.
I did not want to cut my baby just to temporary fit a headlight, as in your link. and I hope to find the right one soon.
But thank you for your help.
