19-10-2021, 07:59 PM | #1 | ||
Hi All
My grandson has wrecked the syncro's on 1st and 2nd I'm in Melb and looking at "help yourself wreckers" for a donor gearbox Not finding much for "LV" 2009-2011 Are there earlier or later year Focus gearboxes I can use ?? I'm aware his Focus uses a 2.0 ltr Mazda engine So is the Mazda 5 speed an option Just worried the clutch input (shaft) maybe different between Ford Mazda Thanks in advance Rodo |
19-10-2021, 08:28 PM | #2 | ||
The 5 speed manual in LV Focus is a Getrag B5A transmission and unique in the same setup for LV Focus, ie you cannot use another B5A transmission from other makes and even Ford models.
You can get you a brand new one for around $3000. Can help with this if need be. |
21-10-2021, 10:41 AM | #3 | ||
I found a B5A Getrag manual trans with this Part # BM5R 7002 LRA
Will it suit Focus LV 2009-2011 with Duratec 2.0 Petrol engine Thanks rodo |
21-10-2021, 12:21 PM | #4 | |||
You need 8M5R 7002 KC or 8M5R7002FF pending on your car. A VIN will confirm which one you need. The first part number is the one worth $3K new. |
21-10-2021, 01:12 PM | #5 | ||
Hmmmmmm
These are a minefield LV went from May 2009 - Aug 2011 There's a MKl May 09 - Aug 11 Then MKll Aug 11 - Aug 12 I guess this is the reason for 2 gearbox part #'s you have quoted Thanks by the way - much appreciated His Vin is AFAUXXMJDUAJ00331 2010 LV Focus Hatch Cheers |
21-10-2021, 01:18 PM | #6 | |||
21-10-2021, 01:32 PM | #7 | ||
Can you just get the synchro's replaced ???
21-10-2021, 01:46 PM | #8 | ||
21-10-2021, 07:42 PM | #9 | ||
Yes it may come to that
I'm use to these - used on 3rd 4th 5th https://www.bearingkits.co.uk/Ford-i...k-ring/871.htm 1st and 2nd are a bit funky and $$$$$ https://www.bearingkits.co.uk/Ford-i...ng-set/868.htm |
21-10-2021, 10:21 PM | #10 | ||
Here is first and second gear parts.
If you let me know what you need, can advise price for genuine Ford parts. LV 1st 2nd Gear.PNG |
23-10-2021, 10:11 AM | #11 | ||
A week on
He claim's "I've figured it out now - no grinding at all" Hmm - is he right - I tried double clutching - slow / fast engage I found slow was best and told him to treat it really really nice Next - because the oil has A Probably never been changed (115k on Odo) B Copped a hiding in the last month from clutch related issues I'll try an oil change - wish me luck n watch this space lol |
01-11-2021, 04:58 PM | #12 | ||
Drained the oil mid week - too much brass / bronze in it for my liking
I found 3 transmissions first one $1100 another $900 another $600 I ended up at Harvey "pick a part" wrecker in Langwarrin South $180 with 30 day warranty - wacked it in and it's a winner Thanks all for your help and advise |
