Hey all. I've been looking for driving lights but don't want a longer beam than the headlight high-beams. The roads I drive on where I need the extra light are very long and straight, with trees close to the Rd and plenty of roos around. I'd like to be able to light up the sides of the Rd without blinding oncoming drivers over a km away.
Does anyone make these? I've seen a few smallish 4" ones advertised as work lights but it doesn't sound like they'll be much of an improvement over the factory high beams. Other thought was whether there might be anything that could replace the fog lights (which I never use). Car is a 2013 LW Focus S. Any recommendations? |
Not sure it will work on your car, I have a 4x4 that I have set up with various light.
I have long range LED Spot Lights that will go around 1km. Then I have a LED Light bar to cover the middle range past the standard high beam and it has a LOT more light volume than your standard lights but not much past that. Then I have 'roo' lights that are small LED Spread beam 'work lights' light bars mounted at a 45 degree angle that lights up the side of the road. Each one is controlled by a separate switch so I can use any or all of the above when I activate the high beam lights. Yes I live in regional NSW and do a fair bit of night driving and we have lots of wildlife mainly including roos, deer and wild dogs, we also have wild horses, and escaped cows.
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's In Storage : '74 XB GS 351 Fairmont Sedan XB Falcon Owners Group Mike's Man Cave |
Thanks. Small work lights on an angle could be an option if nobody makes bigger spread-beam round ones (which I'd prefer for aesthetics if I could find any)
Rob
4 inch food beam from Stedi
https://www.stedi.com.au/type-x-evo-4-inch-flood.html Beam angle listed as 30deg. Flood beam on my combo light bar is 60deg. Their photometric graph shows it may still be suitable. Not too long but about 80m each side. Not cheap though.
UA2 TREND 4WD BI TURBO |
#5 | |||
Experienced Member
I have set of these from Jaycar and find these led lights perfect for lighting up the roadway & surroundings, used them all over Australia with satisfaction.
I have the 7" lights and Jaycar also stocks the 9" lights if you prefer bigger. https://www.jaycar.com.au/6000-lumen...sort=relevance |
Is there a specific reason for wanting LED lamps? Secondhand halogens are often quite affordable as people imagine them to be inferior.
#9 | |||
Rob
Plenty of lights available in flood only, if you check out ARB, their Solis and Intensity lamps, also the Bushranger lamps.
The Silver Bullet - BJ74 Where the actions at Ontrack 4wd Club https://www.facebook.com/ontrack4wdclub |
Just get a small lightbar. The 20-ish inch long ones you see everywhere with the egg-carton shaped reflector don't have a lot of throw, but they spread the light quite widely.
#12 | ||||||
just getting back to this. thanks for all the replies and suggestions. Much appreciated.
https://www.jaycar.com.au/p/SL3937 as Prydey said above, the 1lux distance doesn't seem enough. I've seen some other "work light" options that list 1lux a bit longer at ~50m but not sure they'd be much (if any) better than high beams at that distance?? Quote:
I did see a small Stedi one in Repco, but looks like it's mainly for lighting a work area, not for driving. only 52m 1lux https://www.stedi.com.au/micro-v2-13...ght-white.html They've got some little cube ones that could be ok, 129m 1lux. Just wish they had round ones. Possibly the best option I've seen so far though. https://www.stedi.com.au/c4-led-flood-light.html |
