Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
10-06-2024, 02:30 PM | #1981 | ||
10-06-2024, 02:32 PM | #1982 | ||
Rear diff drain plug UH7126051: Can get $30..
10-06-2024, 02:44 PM | #1983 | |||
Barra Turbo > V8
Would one from an earlier falcon work, like this one. https://www.ebay.com.au/itm/15468532...3Avlp_homepage
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
10-06-2024, 04:15 PM | #1984 | |||
10-06-2024, 10:17 PM | #1985 | ||
Regular...with metamusal
11-06-2024, 12:58 AM | #1986 | |||
Falcon/Fairlane/LTD Sedans. 7/2002 to 9/2007 BA9350A: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT (4.0L DOHC VCT EFI OR 5.4 V8 SOHC EFI 24V) BAT9350A: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT (5.4 V8 DOHC EFI 32V OR ALL 4.0 TURBO PETROL ENGINES) 10/2007- BAF29350A: PUMP ASSY - FUEL (4.0L DOHC VCT EFI OR 5.4 V8 SOHC EFI 24V) BAF29350B: PUMP ASSY - FUEL (ALL 4.0 TURBO PETROL ENGINES OR 5.4 V8 DOHC EFI 32V) All Wagons: BA9350B: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT Utes 7/2002-8/2007 BAC9350C: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT (4.0L DOHC VCT EFI) BACT9350A: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT (ALL 4.0 TURBO PETROL ENGINES OR 5.4 V8 DOHC EFI 32V OR 5.4 V8 SOHC EFI 24V) 9/2007 on AR2Z9350BA: PUMP ASSY - FUEL (ALL 4.0 TURBO PETROL ENGINES OR 5.4 V8 DOHC EFI 32V) BAFC29350A: PUMP ASSY - FUEL (4.0L DOHC VCT EFI OR 5.4 V8 SOHC EFI 24V) |
11-06-2024, 02:01 PM | #1987 | ||
Many Thanks you Legend
17-06-2024, 06:37 PM | #1988 | ||
GT,
I've been trying to find out what the part number of the Supply Tank Hose that goes to the radiator, whether it's still available and do you have an image of it? Reason I ask is mine needs replacement. I checked Mackay Rubber and they list a completey different hose that shows a straight hose with a upward bend on both ends. The hose in my vehicle has only one bend. Vehicle in question AU2 6 cylinder year 2000. Thanks |
17-06-2024, 10:38 PM | #1989 | |||
I guess your talking about the large hose that goes from under the resevoir to the radiator, not one of the other two skinnier hoses. If it is then I only have a pic from the catalogue,it has a part number of ER8A365AMC. May be able to source you one, but would need to confirm. Let me know if you want me to chase. GT |
18-06-2024, 03:33 PM | #1990 | ||
Howdy GTL. I'm after a set of 4 pot rear Brembo calipers (from the Premium brake package) to suit an FG, including the mounting brackets and lines if possible. I've seen a couple of sets floating around but I didn't act quick enough or can't drive halfway across the country to pick them up. If figure if anyone can find them, you're the man.
Thanks, Ben
It's easier to get forgiveness than permission. |
18-06-2024, 08:56 PM | #1991 | |||
New or used? I am sure the rear bracket is part of the caliper and bolts straight to the rear hub. GT |
19-06-2024, 09:03 AM | #1994 | ||
19-06-2024, 01:01 PM | #1996 | ||
20-06-2024, 01:03 AM | #1997 | |||
I’d prefer new, but 2nd hand would be ok if new isn’t an option. I can dig up some part numbers tomorrow if it helps. Thanks mate, Ben EDIT: Yes, the bracket is part of the assembly and is usually included with the Ford part number. I’ll get it to you asap.
20-06-2024, 07:56 AM | #1998 | |||
I can get the Genuine Ford Brembo Rear calipers for FG for around $1100 each side plus postage. From what I can tell, there is nothing else you need as they come with the brake line and pads, that is unless you need mounting bolts as the bracket is part of the caliper. Let me know if you want me to source. GT |
20-06-2024, 12:47 PM | #1999 | |||
Hi GT, Yep, that's the one. it goes from under the reservoir to the radiator. Let me know if its still available and cost thanks. Bondy |
20-06-2024, 05:42 PM | #2000 | ||
20-06-2024, 09:41 PM | #2001 | ||
Giddy up.
Hi GT,
Just a query on a SZII Territory Titanium 2016. Are the indicator lenses/clear cover on the LH side mirror available to purchase separately ? or do you have to purchase the whole mirror assembly ? Regards, |
20-06-2024, 10:42 PM | #2002 | |||
Well originally you could buy the lens seperately (part number 9R7Z13B383BA) how ever that part has become obsolete and you have to buy the whole mirror assembly. Would need to confirm exactly, but the mirror assembly is around the $400 mark. If you want me to chase one for you with a definte price, let me know. Cheers, GT |
21-06-2024, 10:51 AM | #2003 | |||
Giddy up.
Cheers. |
21-06-2024, 08:03 PM | #2004 | ||
21-06-2024, 08:42 PM | #2005 | ||
