Old 05-10-2005, 02:53 PM   #1
Lisa
Let's play Dodgeball!
Lisa's Avatar
Default Broken EF Mirror
Does anyone know where I could get a driver's side mirror for an EF Falcon Futura? I've been ringing around and it seems only possible to get the whole thing replaced and because Futura have body coloured mirrors, I'd have to then get it painted. This is looking at setting me back $170 (including 50 to get it painted)
I'm a pov student, so I dont have this much spare money lying around. I would greatly appreciate if anyone knew where I could just get the mirror part (drivers side)
Or if there are any spare light blue side mirror sets out there?...that arn't too expensive. any information or places that you know of that might be of help to me, would be greatly appreciated. :voldar02:
Thanks again
Lisa
Lisa is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 03:11 PM   #2
InitialD
Low and Loud
InitialD's Avatar
What wreckers have you tried in your area?
Jolly Rodgers in Dandenong would most likely have one and are reasonably cheap
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car
1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon :
InitialD is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 04:09 PM   #3
GenesiS
*Smart *** comment here*
GenesiS's Avatar
Thanks again
Lisa
I replaced my passenger side mirror in my EL about three months back, brand new generic mirror was $77 including gst, Ford wanted $120, although that was the balck one only, still at the time the bloke had no color ones in stock but I believe he could order them, fourtnately for me I have a Gli so color isn't an issue :
Anyways, try South Side Motor Wreckers, 678 South Rd Moorabbin 3189, (03) 9555 0677, they are ford specialits, and the bloke that served me was tops!
GenesiS is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 06:55 PM   #4
crannersEL
crannersEL's Avatar
Theres a few out eastern suburbs way inc:
Just Falcons in bayswater kilsyth area
FTG Auto Salvage Ferntree Gully
Pick a part in Kilsyth
Hope these are help to you.
There are heaps in the phone book call around and see what they got
Paul
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2005, 09:31 PM   #5
Papa Smurf
Papa Smurf's Avatar
If you have only broken the GLASS you can buy that part with the plastic backing on it from Ford. You CANT buy a Coloured Mirror from Ford so you will either have to buy a NEW one in Black or search the wreckers for a same coloured one.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2005, 01:26 AM   #6
Lisa
Lisa's Avatar
Thanks for the replies. I should've gone to Ford first, didn't realise they had these things lying around in their service centres. Also didn't realise they actually sold the glass seperatly for a small price ($45) compared to buying a whole new mirror (~$150) Was a little offput by the couple of wreckers I rang telling me I couldn't get the glass by itself insisting I had to order the whole lot and then have a spray paint job done. :
All fixed now, and roadworthy again!
Old 06-01-2006, 06:29 PM   #7
InSinR8
InSinR8's Avatar
Hi all, rather than a new post, I thought Id follow on here. After my wife had an run in with a pole at the shops : we need a new mirror for my EF. There is a company in Vic that imports parts (amongst other things... you'll understand if you look at their ebay shop LOL) and I was thinking of buying this whole unit for $70 (inc post) .....
fef5000ngl from them on ebay. Is it much of a task to install? And has anyone else dealt with these guys before?
Thanks
Al
InSinR8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 07:36 PM   #8
GenesiS
GenesiS's Avatar
You could get the whole thing from a parts salvage place for roughly the same cost, within ten bucks or so... and you wouldn't have the worry of dealing with ebay people.
However to answer the question, no I haven't dealt with them, though FTG and South Side Wreckers keep the mirrors in stock...
The job itself is easy, shouldnt take more than about 15 mins.
1. There's three screws, they're behind a panel in the corner of your door (opposite side to where the mirror mounts to the outside of the car), remove that. I think there's one screw holding that pannel there.
2. That gives you accerss to the three screws holding the mirror to the car, remove these, WHILE holding the mirror, it will then just pull off (at this stage the connector for the electric mirror will pop out, just disconnect it, it's a run of the mill standard electrical clip, the new mirror will have the opposing end all ready on it).
3. Connect the electrical connector, pop the new mirror in its spot, screw it on, replace cover, all done!
1997 4.0L EL Falcon GLi Sedan Auto
2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe
Lowered all round on King Spring Super Lows
Tinted Windows, Pioneer MP3 Player and Audio System
K&N High Flow Air Filter Mounted in Original Air Box
Trip Computer
NGK Sports Performance Leads
NGK Sports Plugs
Autotecnica Oil Catch Can
Last edited by GenesiS; 06-01-2006 at 07:39 PM. Reason: Should mention the electric side of the mirrors hey!
Old 07-01-2006, 12:38 AM   #9
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Thanks again
Lisa
Ebay
http://cgi.ebay.com.au/RH-Electric-D...QQcmdZViewItem
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 10:29 AM   #10
InSinR8
InSinR8's Avatar
Thanks GenisiS
Old 11-06-2024, 06:02 PM   #11
Colin0061
Default Re: Broken EF Mirror
Is the electrical connection inside the mirror assembly or inside the door ?
Colin0061 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2024, 06:35 PM   #12
mad2
Regular...with metamusal
you have to take off the inside door cover to remove the mirror & the connection is pulled out or disconnected when the 3 screws are undone. how ever it's best to unclip the connector before removing the screws.
