Old 22-04-2006, 04:20 PM   #1
K1W1 Dave
Still alive & kicking
K1W1 Dave's Avatar
Default TX5 Problem
Hi guys
I have a 1989 Telstar TX5 2.2 Injected.
My problem that im having with it is once its warmed up it reves up & down between 900 & 200 rpm also running rich
I have changed computors & also the throttle body thinking that all thats left is the Air flow meter or the oxogen sensor.
Any ideas what could be doing this.
Thanks Dave.
EL XR8 made to burn rubber
:evilsasmo IN THE BEGINING THERE WAS TICKFORD
K1W1 Dave is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2006, 06:32 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default yes you better have a look
Air flow meter or the oxygen sensor. will make it run rich and if it has a throttle position sensor
you have changed the ususall things that go wrong
as long as your electronics readings have checked out and the injectors all correct and no faults found
your assumptions are correct
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2006, 01:47 AM   #3
K1W1 Dave
K1W1 Dave's Avatar
Well i found some one who has a running Telstar & they let me borrow their air flow meter then took the car for a test drive all the problems were fixed so problem solved
Now all I have to do is go & buy a air flow meter
Thanks for your advice.
Dave.
