Old 20-07-2023, 12:37 PM   #1
Gazzzaa
Gazzzaa's Avatar
Default Ford EcoBoost engine issues
Some, if not all, of you will be aware of the information here. Bear with me as I correlate the facts and hopefully give you all some useful information. Please note that this information is for petrol engines and NOT diesel engines.
Most of my information is based in the 1.5 litre 4 cylinder EcoBoost, as fitted to the LZ Focus in Australia from about June 2016. This is the car that I drive and was the primary reason for my research. However, my research on the net has also picked up similar problems with the 1.0 litre, 1.6 litre and 2.0 litre engines, the latter 2 being 4 cylinder engines. Anecdotally, the problems may also occur with the 2.3 litre EcoBoost, but I have not researched this personally. I encourage anyone with this engine to do their own research.
As you are aware, Ford EcoBoost Turbo engines have problems, many related to a design fault that allows coolant to leak into (usually) No.1 cylinder. There are temporary fixes for this problem such as head gasket replacement (in my instance) or Ford USA Technical Service Bulletin 19-2139 from November 2019, which is quite comprehensive (7 pages) but is ultimately a fix only. The only permanent solution is an engine replacement with a new engine incorporating a design adjustment to fix the original design fault.
Because these engines sold well overseas, there have been class actions against Ford in the US (see ClassAction.org) the UK (see FordAuthority.com) and only last week in Canada. These engines sold poorly in Australia, so there are not the numbers to really do anything much in Australia.
The problem has existed since approximately 2010 and was finally fixed with the release of newly designed engines in April-May-June of 2019. For example, any 2.0 litre turbo sold in Australia and built on or before 16 May 2019 (Mondeo, Escape, Focus ST) will eventually succumb to this problem.
Ford Australia know that the problem exists but are hoping that it quietly goes away. Let's face it, their marketing efforts were so appalling that they sold relatively few of these engines anyway.
My experience is as follows. In early Feb 2023 it began with a slight 'miss' when accelerating and the engine was running on 3 cylinders within a week. The RACV patrolman picked up no faults with his OBD2 tool, but he suspected a cylinder was out and diagnosed the presence of water in cylinder 1. My local Ford Dealer had been experiencing staffing issues for some time and a lack of mechanics meant that it took two weeks to repair. I was charged $260 for the head gasket to be replaced.
Fast forward to early June and the engine began to 'miss' again. I hadn't driven the car for the entire month of April because I was overseas on holiday. This time I researched the problem extensively on the internet and arrived at the local Ford dealer, armed with an extensive folio of printed material that backed up my assertions. I left the car there on 08 June. I called on 13 June because I had heard nothing and was told that Ford had agreed to replace my engine with a new 'updated' engine as a 'goodwill' gesture. The car was out of warranty but their 'goodwill' extended to 7 years from the build date. I was one month short of this, thankfully.
The next 5 weeks was full of phone calls, visits, emails, text messages etc, all initiated by me, because no-one at the dealership or Ford Australia was updating me on anything. In the middle of this, I suffered a family bereavement, and to top it off, my wife's Ford Kuga broke down with a DPF problem that the dealer could not look at for 4 weeks. We were borrowing cars to get around and still not getting any answers from anyone and, eventually, I blew a fuse. I marched into the Ford dealership, asked to see either the service manager or the dealer principal on 11 June and said that I wasn't leaving until I knew when I was getting my car back.
Long story short, a local diesel specialist fixed the Kuga and he will now get my future business. The original Ford service manager had 'left' in June and his replacement was true to her work and my Focus was back with me, with a new donk, on 18 June.
The total cost to me was $560 for a new manifold and oil/water separator. The $260 from February 2023 was refunded by Ford Australia. At no stage did anyone argue with me about the extent of the problem. Ford Australia and their dealers are aware. Bear in mind the quoted 7 year 'goodwill' period and if you have an affected vehicle, gather as much information as you can and approach your dealer with confidence.
2016 LZ Focus Sport 1.5 turbo petrol
2013 Kuga Titanium 2.0 turbo diesel
Gazzzaa is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2023, 08:13 PM   #2
Default Re: Ford EcoBoost engine issues
Yes a guy in my townhouse complex had an Lz 1.5 sport. Ford replaced the engine at Ford s cost. He then sold it and on his second Cx 5.
I had an Lz 1.5 manual which I traded in on a Skoda when the Lz reached 129000 motor was ok but it mainly did freeway work
I now have a 2022 Puma with the one litre ecoboost three cyl. I m hoping Ford have changed the engine design to avoid issues.
kevino is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2023, 09:54 PM   #3
VicVic
Gazzzaa - thanks so much for this comprehensive post. I got the LZ Sport "serviced" whilst my husband was overseas as it started missing. The replaced all coils and sparks and it seemed to be fine. The is started misbehaving again and eventually overheated and was low in coolant. NRMA patrolman diagnosed leaking head gasket, topped up water, we limped it home (no overheating for this short trip) and it was towed to Ford dealer today.
I will be doing the same as you and dropping in a folio of printed material to help them along with the full repair. Thanks again.
The Original Foal - 2015 Ford Focus LZ Sport in Magnetic (gone)
The upgraded Foal - 2018 Ford Focus LZ Sport in Winning Blue
The replacement Greyee - 2015 Ford Focus LZ Trend in Magnetic (gone)
New daily - 2022 Ford Focus Active in Silver
Extra new daily - 2018 Ford Focus LZ Sport in Candy Red
VicVic is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2023, 12:26 PM   #4
VicVic
Update from me: all fixed now. Dominelli Ford replaced the full long engine at no cost to me. I was so relieved. And it was so stressful at the time, but Ford were really good about it all. They even gave the hubbie a loan car whilst it was getting done.
Phew!
Old 14-05-2024, 08:49 AM   #5
samsy351
351XB - Underbelly II Car
samsy351's Avatar
Hi guys would like to pm either if you about how you went about getting this issue sorted with Ford
How your experience was and any difficulties etc
FALCON XB 351 - UNDERBELLY II CAR
samsy351 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2024, 08:34 PM   #6
Focus2016
Hi team, have just come across your posts as my 2016 Focus 1.5 Sport has the same issue. Purchased used from the Ford dealership last August, engine had been misfiring so took it in to Ford service centre turns out it has a cracked head and entire engine needs replaced. Anywho, I’ve read plenty about this being a known issue overseas but not a lot here in Australia. If you guys would be willing to share any info or guidance you have about this issue I would really appreciate it as I’m super stressed and confused about where to go from here as I purchased the Focus used and apparently Ford have said that as I’m not the originally owner they won’t do anything about it. Don’t really know what I’m asking, I guess I’m just venting but if you do have any info that would help I would be grateful! Thanks
Focus2016 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2024, 09:49 PM   #7
VicVic
Definitely can be fixed by ford. I was not the original owner of mine either. I would call Ford Australia, tell them what's happened, tell them you know that it has been acknowledged as an issue with this kind of engine in Australia as well as in Canada and the US and ask them to log a case. They'll give you a case number and then when you book it in with your local Ford dealer you give them the case number ring forward back and say listen. I've taken it down to my local dealership. I've given them the case number they going to check it out for me. They'll talk to each other and next thing you'll get a phone call saying that they're going to replace the long engine at no cost but be warned it could take 8 to 12 weeks.
Old 28-05-2024, 09:54 PM   #8
VicVic
Sorry, a few little issues with the voice to text there. Essentially what happened with me was that I had exactly the same issue as Gazza. It was missing them overheating . Coolant leaked into the head and eventually caused it to crack. I rang Ford Australia. I got a case number. I rang my local dealer they said bring it down and we'll have a look at it. And gave them the Ford Australia case number and then they spoke to each other and next thing I got a phone call saying it'll be replaced at no cost to you. Ford Australia even supplied a replacement car for the long time that we were awaiting a replacement engine.
Old 29-05-2024, 01:44 PM   #9
Focus2016
Hi VicVic, thanks for your quick response!! Just spoke to Ford and they were no help, I mentioned that Ford know that it's an issue etc. but because as already back at the dealers/service centre (has been since last week) and apparently the dealer/service centre would've already spoken to Ford Australia to "see what they could do" because its "5 years out of warranty". Ughhhh, this is so frustrating to know that they have fixed this known issue for others recently but I seem to luck out, maybe because 'females don't know stuff about cars and will just pay the $12,000 they want to fix it?!' Ha! Ugh!!!
Old 29-05-2024, 05:49 PM   #10
VicVic
Yes I understand your frustration. VicVic is a chick too. Print out the class action documents And take them into your dealership. No one wants to be on the front page of the newspaper, And being out of warranty shouldn't be an issue if it's a manufacturing defect which all of the class action information indicates that it is. Just to be clear, mine and gazzas and the other example were all LZ 1.5 EcoBoost ford focus if that helps. Mine was 2018.
Old 15-06-2024, 10:02 PM   #11
Must16
I have an 2016 Mustang with the 2.3 motor. I have been checking the coolant level which has dropped from half down 50mm lower. Also checked the oil filler cap and its got an oily sludge on the inside. The exhaust blows white smoke (not excessive but stops after a while) I bought the car 2weeks ago and its still under dealer warranty. This started happening after a week of ownership.
The car has been checked and no leak was found,but its going back this week as the coolant has been dropping level. But lets see what they say when they check the car on tuesday.
Must16 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2024, 01:26 PM   #12
Franco Cozzo
Franco Cozzo's Avatar
Having the same issues with 1.6L Ecoboost in my Fiesta ST, split its header tank recently so replaced the tank and all its hoses with new genuine items.
Rough idle for about 20 seconds on cold start when its been sitting, a bit of white smoke out the exhaust at idle when at operating temperature that comes and goes and I'm losing coolant slowly - can't see any leaks.
I reckon its the dreaded block issue on mine, next thing for me is coolant leakdown/pressure test and bore scope in the cylinders I think to see.
Hopefully yours isn't similar, not sure if 2.3L ecoboost is open deck like the 1.6L and has the stupid cooling slots.
Mines got 230,000km on the clock now.
Old 18-06-2024, 09:58 AM   #13
safari_rider
To those who have gotten full goodwill - what did you tell the dealer?
I have just gotten a quote for over 15k to fix the coolant intrusion, and Ford Aus has only offered me 50%. Leave over 7.5k for me!
What can I do?
safari_rider is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2024, 02:12 PM   #14
Franco Cozzo
What can I do?
The 'fix' is a new long motor unfortunately, how old is the car? Mines 9 years old so I don't think Ford would offer me any good will
Old 18-06-2024, 02:17 PM   #15
safari_rider
The dealership has not given me a quote per se, just the price - hoping they can send the quote. I thought that perhaps they could just do a short motor? This one was just under 7 y.o. when the issue started.
Old 18-06-2024, 06:56 PM   #16
Must16
Just got the car back from the dealer, they checked under the rocker cover with an inspection camera. No sludge, oil condition ok. As for the cooling Carried out pressure test-all ok. visual inspection -no leaks. But this reason was given for the low level. Coolant system is under high pressure which makes coolant level go down, however once you open coolant cap coolant level goes up. Any thoughts?
Old 21-06-2024, 04:55 PM   #17
Must16
Well i took the car to my mech for a second opinion. He suggested that i should look at getting a TK test done. He carried out the test then and there. What this is a simple 3 min test where they run the car and fit a tube to the radiator and fill it with a blue liquid. Theory has it the liquid should stay blue, if the engine is ok, but turning yellow in 2 minutes indicates exhaust gases in the cooling system.( thats what we saw when we did the test on the Mustang) . So now back to the dealer on monday and ask them to perform the same test and watch what the say.
Old 10-07-2024, 04:41 PM   #18
RayDavo
Does anyone know where we can get the class action documents and are they valid in Australia?
We have been given the run around from both the dealer and Fords CRC department. These guys lie, do not return calls AND WILL NOT SUPPLY INFORMATION when asked for. They couldn’t even get the year model of the car correct.
RayDavo is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2024, 03:34 PM   #19
RayDavo
To those who have gotten full goodwill - what did you tell the dealer?I have just gotten a quote for over 15k to fix the coolant intrusion, and Ford Aus has only offered me 50%. Leave over 7.5k for me!What can I do?
Hi, We haven't even been given assistance. Ford CRC and the dealer have basically wiped us after trying to deal with them over a 3 month period. I was thinking of how best to approach this and thought it might be good to get at least 7 people together to start a class action. It won't matter if Ford have opted to give some assistance or zero assistance as this is a known issue and they really should address this the same across the board with a zero cost engine replacement.
Is anyone interested in joining in to approach them together?
Does anyone else have a better option or any contacts withing FORD CRC that might listen to us
Old 21-08-2024, 11:07 PM   #20
NickosBF2XRT
NickosBF2XRT's Avatar
I'm down for a class action, just bought a Kuga and it struggles to get up hills, 2.0 ecoboost
BF MK2 XR6 TURBO 277RWKW
EL XR8 - UGL-170
NickosBF2XRT is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2024, 07:21 AM   #21
JIMBOJOHNSON80
Should I be worried? 2016 LZ Sport with 100k kms. Was hoping to get another 50 thousand it's been such a good runabout for me since I've had it.
JIMBOJOHNSON80 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2024, 05:25 PM   #22
Dr Smith
Just wanted to report my sister's 2017 Escape has been quoted for a $16K repair bill for this issue. I've done a quick online search to discover the reported cases overseas as I/we had no idea. Her car has just under 70K km, bought brand new and only serviced by Ford dealers.
Dr Smith is offline   Reply With Quote Multi-Quote with this Post
