Old 06-11-2022, 07:45 PM   #61
NCII40
XR6T BA 2002
NCII40's Avatar
Default Re: BA BF C5 325mm Brake Kits cheap
Originally Posted by FLOORED View Post
The offset of the disc is also different from the two rotors . The C5 BA Ford GT or PBR optioned kits are better as the caliper is also more rigid.
325 x 32 C5 Disc
322 x 28 XR6T XR8 disc
here are some pics for comparison
XR6T 2002 BA
Old 17-04-2024, 07:27 AM   #62
NCII40
XR6T BA 2002
NCII40's Avatar
Looks like they made a return
Hopefully the bolt holes line up
i will buy a set for trial
XR6T 2002 BA
Old 17-04-2024, 08:47 AM   #63
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The bolt holes and offset won't line up because they are for a Chev and not a Ford. The caliper cradle (some call it a bracket) is different for each car eg HSV , FORD and Chev along with the Toyota they fitted them too.
Wjhat we may be able to do is use them for the 355mm kits we used to do back in the day if they fit the 32mm disc.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 17-04-2024, 07:30 PM   #64
NCII40
XR6T BA 2002
NCII40's Avatar
Lets do this !
XR6T 2002 BA
Old 18-04-2024, 08:56 AM   #65
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Lets do this !
When you get them you can send a pair to me and we will have a look.
MATTHEW PEARCE
Phone 02 9609 1101
Old 18-04-2024, 08:00 PM   #66
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks Matt
Update, It's Powerstop that are making them
Power Stop calipers and the brackets are remanufactured in our Chicago, IL facility
Power Stop calipers are 100% pressure tested to verify piston operation and prevent any possible leaks from occurring. This insures that every caliper is inspected for quality and safety. Every caliper kit is expertly assembled using new pistons, seals, slide pins (where applicable), dust boots, bleeder screws, and stainless steel brake pad abutment clips. High temperature EPDM rubber dust boots and premium silicone lubricant.
XR6T 2002 BA
Old 24-10-2024, 08:49 AM   #67
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thanks Matt
Did you get them at all ?
MATTHEW PEARCE
Phone 02 9609 1101
