Old 19-06-2006, 06:38 PM   #1
mustang
mustang's Avatar
Default fuses
can someone tell me if there are two fuse boxes if so can u tell me where the second one is i know where the one is under the bonnet?
also under the same sort of thing i cant figure out why i havent got any indicators or horn any help would be good
thankz Mustang
1980 Coupe, Blue, 1.6L, 2" exhaust and extractors.
Oversteer Scares The Passengers , Understeer Scares The Driver
WWW.QLDSTREETSCENE.COM/
mustang is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2006, 02:41 PM   #2
mustang
mustang's Avatar
does this mean noone can help me?
Old 22-06-2006, 11:23 AM   #3
T3man
T3man's Avatar
Maybe no one knows to what sort of car you're referring ???
If it's an Esky there is indeed only one set of fuses. If you have tested the circuits for power to the multiplug under your steering column that supplies the indicator stalk then the problem is most likely in the stalk. It is the only "common" denominator from what you've said.
Old 22-06-2006, 04:04 PM   #4
satria
FOXWHO
satria's Avatar
he has that blue escort 1.6L. I remember he posted pics of it.
My indicators stuffed up on me once (i never checked if the lights were actually working or if it was just the dash screwing up) but the wire came loose from the back of the alternator. Put it back on and it works fine now. hope that helps.
What part of aus are you in mustang?
satria is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2006, 12:01 AM   #5
mustang
mustang's Avatar
cairns qld
Old 26-06-2006, 12:02 AM   #6
mustang
mustang's Avatar
Quote(sig):1980 Coupe, Blue, 1.6L, 2" exhaust and extractors.
Old 26-06-2006, 10:50 AM   #7
T3man
T3man's Avatar
*QUOTE* "Username = Mustang" ???
Maybe you need to put "Escort" in your sig. so people don't have to guess ... after all it is YOU asking for help.
Anyhow, did you sort your prob?
PS Arm and hand signals are still legal in QLD if your indicators don't work - oh, and you can use "the finger" for your horn.
