Old 28-09-2009, 07:33 PM   #31
The Monty
Just slidin'
The Monty's Avatar
You can just hold in the reset button as well, and it will go away. It works on AU1's also.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 28-09-2009, 09:56 PM   #32
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Originally Posted by 51OAU
does it stay on or go away?
Yeah stays on until you hold down the stalk for 11 seconds or more
Old 29-09-2009, 06:23 PM   #33
Halfmo Rocks
Bearded Hermit
4 times was the charm...damn, i'm gonna have fun with that...i think we owe Dark Horse a case of beer - thanks mate
Halfmo Rocks is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2009, 10:11 PM   #34
TheInterceptor
Cruising...
TheInterceptor's Avatar
yeh sure haha
D mode also comes with a bonus...The look on peoples faces when you tell them your AU has features that a Merc would have!
And then the face you get when you say your AU is better than the Merc!
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2009, 01:15 PM   #35
tickfrd6
what is the use of doing this to your cluster? what does it do? does it show your speed in digital as well? i don't get it :
tickfrd6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2009, 02:03 PM   #36
Beer Baron
Shows RPM and speed in a digital read out, 3km difference between the digital display and the needle. Oil pressure and battery volts. Also can be set to just flash Ford on the display.
Took me 1 go with a timer after about 30 goes without.
Beer Baron ;)
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2009, 03:30 PM   #37
fourl6
AU Falcon Man
fourl6's Avatar
Beer Baron ;)
can be handy to check things like battery voltage and fuel usage, also gives you a fuel tank reading in litres (buffered and un buffered)
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2009, 07:09 PM   #38
Beer Baron
Shows a blank screen when you 1st get into diagnosis mode.
Shows a full screen then the Ford screen.
Mine doesn't show oil pressure, Just battery voltage.
Gear position is 1234567.
A/C off is 1100 A/C on is 1111.
Cruise control cant be seen on the display when in diagnosis mode but still works.
3kph difference between digital readout and needle.
Revs are also different but not by much. 100rpm difference at some rev ranges and same at others.
Beer Baron ;)
AU XLS.
Old 15-11-2009, 02:34 AM   #39
Venomous1
5.0 means business
Venomous1's Avatar
What this thread really needs is a pic of somebody using the function because sounds good but wanted to actually just get a preview of what it looks like in effect.
Windsor V8 Enthusiast!
Turbo Barra Lover!
Venomous1 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2009, 06:16 PM   #40
99_falcon
Originally Posted by DJM83
I tried it 4 times without a timer and on the 5th time without a timer i got it
I got about the same
I6 All the way
99_falcon is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2009, 08:54 PM   #41
99_falcon
What does it mean by buffered and un-buffered?
I6 All the way
Old 15-11-2009, 09:58 PM   #42
STHSV8
STHSV8's Avatar
Unbuffered gives you a "live" reading that if you were driving would be all over the shop as the fuel sloshes around in the tank. Buffered allows you to be moving and takes an average from the sender to give you a reasonably accurate reading.
STHSV8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2009, 12:58 AM   #43
99_falcon
In my thread, "AU Fuel Econ" on the AU forum I have a photo of this in use.
I6 All the way
Old 16-11-2009, 11:09 AM   #44
Mechan1k
Mechan1k's Avatar
oil pressure will read 0 in vehicles without an oil pressure gauge ... it's just disaplying that the warning light isn't on (ie: no fault).
I'm pretty sure if the oil pressure light were to be on during a fault ... it'd display a 1
That's from what i remember.
DTE is also shown in the diagnostic mode as well.
Old 16-11-2009, 05:17 PM   #45
99_falcon
What number (ie. 1-19 i think it goes to) is DTE?
I6 All the way
Old 16-11-2009, 05:52 PM   #46
fourl6
AU Falcon Man
fourl6's Avatar
when you take off it will drop a heap... say down to 10l the when you brake hard it'll go up to like 60l... (on un buffered)
Was
Old 16-11-2009, 10:58 PM   #47
Mechan1k
Mechan1k's Avatar
Option 2 I think ... next to the coolant temp.
Has been a while since i checked it .... as I traded my AU a while ago now.
Old 16-11-2009, 11:36 PM   #48
99_falcon
I find it easier to do without timing it on a stopwatch. Takes me a few goes to get it but usually no more than 5.
I6 All the way
Old 12-12-2009, 12:35 PM   #49
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
Finally got around to playing with this. I think it's useful and cool. Below is a graphical representation of the button sequence, with second count, in case that helps someone. Why it had to be so complex is beyond me.
0 1 2 3 4 5 6 7 8 9 1 2 3 4 5 1 2 3 4 5 6 7 1 2 3 4 5 1 2 3 4 5 6 7
_ - _ - _ - _ - _ - - - - - - _ _ _ _ _ _ _ - - - - - _ _ _ _ _ _ _
I would like to try and show the modes in a clearer, more print-friendly format, like a table, but can't see how to do that.
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2009, 12:25 AM   #50
KR1STO
Just another mock-up..
KR1STO's Avatar
does this work definately on series 1?
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2009, 12:43 AM   #51
KR1STO
KR1STO's Avatar
forget my last post.. yep it does work on series 1.. just tried it..
just wondering.. is it supposed to show you a digital read out of your speed?
cos i can't seem to find that bit..
see my car here:
[SIGPIC][/SIGPIC]
Old 13-12-2009, 08:10 AM   #52
lofty
Rusticating
lofty's Avatar
Yes it's mode 3, on the bottom. Er, you'll have to be moving. :O
Old 13-12-2009, 10:01 AM   #53
KR1STO
KR1STO's Avatar
hahaha.. of course..
cheers mate..
see my car here:
[SIGPIC][/SIGPIC]
Old 07-01-2010, 08:01 PM   #54
EgoFalcon
The Villan
EgoFalcon's Avatar
Hey guys and gals, I did a video representation on my phone which has bad quality and doesnt have verbal instructions, but shows me putting the car into diagnostics mode. Also directed people to this thread on written response on how to.
http://www.youtube.com/watch?v=T3gSPDFLDDU
The car was an AU series 1 Fairmont Ghia.
New addition! 2010 FG XR50 Turbo in Lightning Strike
The PX Ranger has arrived! XLT Metropolitean Grey
Previous Ride - 2007 BF MK II XR6 in Lightning Strike
EgoFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2010, 10:33 PM   #55
Highway
Highway's Avatar
Interesting stuff.. going to have to have a look at this myself..
FG XR6 in VIPER
AND SALESMAN SPECS AUII WAGON
Highway is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2011, 04:09 PM   #56
347 mont
347 mont's Avatar
It certainly does work, however I put mine back to normal display as I dont think its well laid out. Its funny I have a 2001 Ghia and my friend bought a base model FG ute, and his dash has many more features than the Fairmont. For example the ute has alll the same as I have ie ave kmph, av/L per 100, range till empty, inst km/100 as well as many others, eg litres in the tank, how many ltr used since last fill, time since last fill, averages for that particular tank of fuel as well as averages since last reset and others that I thought were mint. Hmmm FG dash in an AU, now that would be something ha ha.
Losing my patients with unfinished threads
Did the ideas people helped you with work or not!
347 mont is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2011, 07:39 PM   #57
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
mmm... i know what its going to be set on in the AU from now on.. have been trying for a bloody long time and have finally got it working..
i also "accidentally" hit the limiter playing with the RPM one too
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2011, 10:35 PM   #58
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I changed mine over today, I havn't been for a drive yet to see if I like the function or not.
Old 18-03-2011, 07:47 PM   #59
enforcerfpv
enforcerfpv's Avatar
Default Re: Hidden functions of AU dash cluster...
i just tried this and got it first go just counting without watch certainly does work but changed mine back to normal, didnt like the diag mode display at all really.
enforcerfpv is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2011, 07:52 PM   #60
galaxy xr8
Giddy up.
galaxy xr8's Avatar
The only thing I really like about it is the digital speedo readout.
It's a little to small to read for us oldies aswell, lol.
